Using the program:
#include <ArduinoJson.h>
#include <Ethernet.h>
#include <SPI.h>
delay(4000);
// Initialize Serial port
while (!Serial) continue;
// Initialize Ethernet library
byte mac[] = {0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED};
Ethernet.init(8); // use pin 53 for Ethernet CS
if (!Ethernet.begin(mac)) {
Serial.println(F("Failed to configure Ethernet"));
return;
delay(4000);
Serial.println(F("Connecting..."));
// Connect to HTTP server
EthernetClient client;
client.setTimeout(10000);
if (!client.connect("arduinojson.org", 80)) {
Serial.println(F("Connection failed"));
return;
Serial.println(F("Connected!"));
// Send HTTP request
client.println(F("GET /example.json HTTP/1.0"));
client.println(F("Host: arduinojson.org"));
client.println(F("Connection: close"));
if (client.println() == 0) {
Serial.println(F("Failed to send request"));
return;
// Check HTTP status
char status[32] = {0};
client.readBytesUntil('\r', status, sizeof(status));
if (strcmp(status, "HTTP/1.1 200 OK") != 0) {
Serial.print(F("Unexpected response: "));
Serial.println(status);
return;
// Skip HTTP headers
char endOfHeaders[] = "\r\n\r\n";
if (!client.find(endOfHeaders)) {
Serial.println(F("Invalid response"));
return;
// Allocate JsonBuffer
// Use Redirecting… to compute the capacity.
const size_t capacity = JSON_OBJECT_SIZE(3) + JSON_ARRAY_SIZE(2) + 60;
DynamicJsonBuffer jsonBuffer(capacity);
// Parse JSON object
JsonObject& root = jsonBuffer.parseObject(client);
if (!root.success()) {
Serial.println(F("Parsing failed!"));
return;
// Extract values
Serial.println(F("Response:"));
Serial.println(root["sensor"].as<char*>());
Serial.println(root["time"].as<char*>());
Serial.println(root["data"][0].as<char*>());
Serial.println(root["data"][1].as<char*>());
// Disconnect
client.stop();
// not used in this example
I should get a nice JSON response but instead of them, I'm getting something as you can see in screenshot. Could you please help me where is the problem?
