Problem with interrupt inside a class
Hey everyone,
I am having an issue with my code. I'm not a programming nor C++ expert by any stretch of imagination so please be patient :smiley:
My goal is to create a class that can handle an interrupt on an Arduino Nano. By researching this on the internet, I found out, that I would need to create an interrupt handler as a static method of the class.
My main.cpp looks like this:
#include <Arduino.h>
#include "interruptClass.h"
static const int interrupt_pin = 2;
interruptClass myInterruptClass(interrupt_pin);
  Serial.println(myInterruptClass.getCounter());
My interruptClass header file looks like this:
#pragma once
class interruptClass
    public:
        interruptClass(int interrupt_pin);
        unsigned long getCounter();
    private:
        static void interruptHandler();
        void increment();
        int m_interrupt_pin;
        volatile unsigned long m_counter = 0;
My interruptClass.cpp looks like this:
interruptClass::interruptClass(int interrupt_pin):
m_interrupt_pin(interrupt_pin)
    pinMode(m_interrupt_pin, INPUT);
    attachInterrupt(digitalPinToInterrupt(m_interrupt_pin), interruptClass::interruptHandler, RISING);
void interruptClass::interruptHandler()
    static interruptClass *instance = nullptr;
    if (instance)
        instance->increment();
void interruptClass::increment()
    m_counter++;
unsigned long interruptClass::getCounter()
    return m_counter;
However, the interrupt does not trigger. What am I doing wrong?
Thank you very much!
I not seen where you assign anything to your instance pointer.
You should not do hardware related stuff in your constructor. Add a begin method to the class where you set the pinMode and attach the interrupt.
@b707 How would I do it correctly? I have never before worked with something like this and the code from the interruptHandler is right out of ChatGPT :smiley:
@sterretje Thank you for your hint! I created a public begin function that is being called in the setup part of the main.cpp. However this didn't resolve the issue.
I would move the instanse variable to the class definition instead the method and add
instance = this;
to the constructor.
I added the following to the private members of the class:
static interruptClass *instance;
Then, I added the line
instance = this;
to the constructor in between the braces.
The content of the interruptHandler method is now reduced to:
However, if I want to compile, I get the following error:
C:\Users\User\AppData\Local\Temp\ccbcijcg.ltrans0.ltrans.o: In function interruptClass::interruptHandler()': <artificial>:(.text+0x21e): undefined reference to interruptClass::instance'
:(.text+0x222): undefined reference to interruptClass::instance' C:\Users\User\AppData\Local\Temp\ccbcijcg.ltrans0.ltrans.o: In function global constructors keyed to 65535_0_interruptClass.cpp.o.1788':
:(.text.startup+0x6e): undefined reference to interruptClass::instance' <artificial>:(.text.startup+0x72): undefined reference to interruptClass::instance'
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\nanoatmega328\firmware.elf] Error 1
You need to start with the understanding that any code you get from ChatGPT (or instructables.com) is going to be crap.
For a more general method of handling interrupts in classes, see Post #44 in this Thread.
Why did you decided to make it private?
I followed this approach, which is pretty similar and now it works fine! Thank you guys very much for your help!
