Hi, i have a problem with a IR Sensor (vs1838), i used the library IRremote and changed "WsProgram" to "Arduino.h". But I can't get it to work, i conect the right pin of the sensor at voltage (5v), middel pin at ground and left pin at Arduino Digital Pin number 0.
I tested with public codes but i can't get it work.
Why are you connecting the device to the hardware serial pin? How do you then KNOW it doesn't work? Where IS your code that you were supposed to have posted?
