Problem with mic , preamplified
Dear All,
This Script is not completed, but I have a big problem since the value that I read on the pin A3 continue increasing over time.
(A3 is linked to a Preamplified Microphone).
On the contrary, if i Run a very simple script like the one below, the value does not increase.
Why?
Thank You
Marcello
STUPID SCRIPT (does not increase)
(void setup() {
int lettura = analogRead(A3);
Serial.println(lettura, DEC);
MY SCRIPT (INCREASE)
#define buttonPin 10
#define ledPin 13
#define MicPin 11
#define FlashPin 12
#define ThresholdPin 8
#define SWITCH_PIN A2
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2); // set LCD
int previousState;
int val=0; //Stato del PIN
int old_val=0;
int buttonState= 0;
int micstate=0;
int soglia=1024;
int ThresholdPinState=HIGH;
float fdrange=0;
lcd.init(); // initialize the lcd
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
pinMode(FlashPin,OUTPUT);
pinMode(ThresholdPin,INPUT);
previousState = 0;
while (ThresholdPinState == HIGH) {
ThresholdPinState=digitalRead(ThresholdPin);
soglia=analogRead(A0);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Soglia = ");
lcd.print(soglia);
lcd.print(" ");
lcd.setCursor(0,1);
lcd.print(" ");
float sensorValue1 = analogRead(A0);
float sensorValue2 = analogRead(A1);
int micread = analogRead(A3);
float DelayFlash;
Serial.println(micread, DEC);
// switch range tempi 0-5 0-50 0-1000
int analogValue = analogRead(SWITCH_PIN);
int actualState;
if(analogValue < 100) actualState = 1;
else if(analogValue < 900) actualState = 3;
else actualState = 2;
if(previousState != actualState) {
previousState = actualState;
if (actualState == 1) fdrange = 204.60;
if (actualState == 2) fdrange = 20.46;
if (actualState == 3) fdrange = 1.023;
// Lettura Potenziometri per regolazione Delay
sensorValue1 = 1023 - sensorValue1;
sensorValue2 = 1023 - sensorValue2;
sensorValue1 = sensorValue1/fdrange;
sensorValue2 = sensorValue2/fdrange;
sensorValue2 = sensorValue2/10;
DelayFlash = sensorValue2 + sensorValue1;
val = digitalRead(buttonPin);
digitalWrite(FlashPin, LOW);
// Print Delay on LCD
lcd.setCursor(0,1);
lcd.print("Ritardo = ");
lcd.print(DelayFlash,2);
lcd.print(" ");
//Controlla se il Bottone è stato premuto
if ((val == HIGH) && (old_val == LOW)) {
buttonState = 1 - buttonState;
delay(50);
old_val = val;
if (buttonState == 1) {
// Countdown and Flash
lcd.clear();
lcd.setCursor(0,0);
lcd.print("COUNTDOWN");
digitalWrite(ledPin, HIGH);
lcd.setCursor(0,1);
lcd.print("5 secondi");
delay (1000);
lcd.setCursor(0,1);
lcd.print("4 secondi");
delay (1000);
lcd.setCursor(0,1);
lcd.print("3 secondi");
delay (1000);
lcd.setCursor(0,1);
lcd.print("2 secondi");
delay (1000);
lcd.setCursor(0,1);
lcd.print("1 secondi");
delay (1000);
lcd.setCursor(0,1);
lcd.print("TRIGGER PRONTO!!");
while (micstate <= soglia) {
micstate=analogRead(A3);
delay (DelayFlash);
digitalWrite(FlashPin, HIGH);
digitalWrite(ledPin, LOW);
lcd.clear();
micstate = 0;
buttonState = 0;
else {
// turn LED off:
Read the how to use this forum sticky then go an put code tags round that code.
( The </> icon )
Have you connected the ground of your amplifier to the ground of your Arduino?
Have you AC coupled your amplifier?
Have you biased the input pin?
Hi Mike,
*yes
*yes
*could you explain my what you mean for (biased the input pin).
Maybe I have found a solution but I'm not sure if it is the right one.
I have put one 50K resistor in parallel between micOUT and GND.
Value that A3 read now i stable and near to 0 with silence.
What do you think about this solution?
Many thanks
Marcello
Sorry but not a lot.
It should be 512 with silence. An audio signal will go either side of zero, so biasing makes the signal 2.5V with nothing out.
Connect another 50K (50K? are you sure ) from A3 to +5V.
