Hi there,
So this is the first time I'm using a MM5450 chip, the aim being to drive 30+ fans which will inflate some latex gloves (hence the variable names).
I've generated a array of 36 values which consist of alternate ON/OFF pattern to test it but I've failed to make it work :(.
Is anyone able to point in the right direction?
Thanks!
// A function to interface the Arduino to a high I/O count shift-register chip type M5450.
// This takes an array of values and writes the states to the 34 outputs of the M5450 chip.
// What constants are used in this program? (Follow the UPPERCASE convention).
const int NUMBITS = 36; // MM5450 sentence length.
// What is the alias for hardware input and output (I/O) pins used? (Follow the camelCase convention)
// MM5450
int clockPin = 3;
int dataPin = 4;
int dataEnable = 5;
// What are the variables of the system that this program controls?
int i;
boolean gloveStates [NUMBITS];
boolean gloveState;
// Bootstrap the hardware (I/O) and initialise the values of system variables and parameters.
pinMode(clockPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(dataEnable, OUTPUT);
digitalWrite(dataEnable, HIGH); // outputs DISabled.
// Generate initial off states:
gloveState = false;
for (i = 0; i < NUMBITS; i++) {
gloveStates [i] = gloveState;
serialMM5450Write(); // Call the function that write the gloveStates to the shift register.
// when the MM5450 registers are set to zero then release DATA ENABLE
digitalWrite(dataEnable, LOW); // outputs enabled.
pinMode(ledPin, OUTPUT);
// Start the main program loop:
// Insert here the code you want to run wherever the sequenced processes are not running:
alternateTestPattern1();
printState(); // .
alternateTestPattern2();
printState(); // .
void serialMM5450Write() {
// nitty gritty of taking the array and writing each element of the array into the registers of the chip
digitalWrite(clockPin, LOW); // initialise pin state.
delayMicroseconds(100);
digitalWrite(dataPin, LOW);
digitalWrite(clockPin, HIGH); // clock the data into the register.
digitalWrite(dataPin, HIGH);
for (i = 0; i < 36; i++) {
// Specify the data state.
if (gloveStates[i] == true) {
} else if (gloveStates[i] == false) {
digitalWrite(clockPin, LOW); // .
return;
void printState() {
Serial.print("1 ");
Serial.print("0 ");
Serial.println(" ");
void alternateTestPattern1() {
// Generate arbitary test pattern of alternate on/off states:
gloveState = true;
gloveStates[i] = gloveState;
// toggle gloveState
if (gloveState == true) {
gloveState = false;
gloveState = true;
* gloveStates [0] = true;
for (i = 1; i < NUMBITS; i++) {
if (gloveStates[i - 1] == true) {
gloveStates[i] == false;
if (gloveStates[i - 1] == false) {
gloveStates [i] = true;
void alternateTestPattern2() {
gloveState = false;
gloveState = false;
gloveState = true;
