Hi
I have a little code that I use to test my panel, but the numbers are not formed correctly
I use the neomatrix library, ESP8266 and ws2813 leds
This is the code
#include <Adafruit_GFX.h>
#include <Adafruit_NeoMatrix.h>
#include <Fonts/FreeSans9pt7b.h>
#ifndef PSTR
#define PSTR // Make Arduino Due happy
#endif
#define PIN D6
unsigned long start, tiempo = 0;
// MATRIX DECLARATION:
// Parameter 1 = width of NeoPixel matrix
// Parameter 2 = height of matrix
// Parameter 3 = pin number (most are valid)
// Parameter 4 = matrix layout flags, add together as needed:
// NEO_MATRIX_TOP, NEO_MATRIX_BOTTOM, NEO_MATRIX_LEFT, NEO_MATRIX_RIGHT:
// Position of the FIRST LED in the matrix; pick two, e.g.
// NEO_MATRIX_TOP + NEO_MATRIX_LEFT for the top-left corner.
// NEO_MATRIX_ROWS, NEO_MATRIX_COLUMNS: LEDs are arranged in horizontal
// rows or in vertical columns, respectively; pick one or the other.
// NEO_MATRIX_PROGRESSIVE, NEO_MATRIX_ZIGZAG: all rows/columns proceed
// in the same order, or alternate lines reverse direction; pick one.
// See example below for these values in action.
// Parameter 5 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_GRBW Pixels are wired for GRBW bitstream (RGB+W NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
// Example for NeoPixel Shield. In this application we'd like to use it
// as a 5x8 tall matrix, with the USB port positioned at the top of the
// Arduino. When held that way, the first pixel is at the top right, and
// lines are arranged in columns, progressive order. The shield uses
// 800 KHz (v2) pixels that expect GRB color data.
Adafruit_NeoMatrix matrix = Adafruit_NeoMatrix(60, 14, 1 , 1, PIN,
NEO_MATRIX_BOTTOM + NEO_MATRIX_RIGHT +
NEO_MATRIX_ROWS + NEO_MATRIX_ZIGZAG,
NEO_GRB + NEO_KHZ800);
const uint16_t colors[] = {
matrix.Color(255, 0, 0), matrix.Color(0, 255, 0), matrix.Color(0, 0, 255) };
matrix.begin();
matrix.setTextWrap(false); // estaba en false y si probamos con un ejemplo de fast led? cambiando los prarametros segun estan aqui
matrix.setFont(&FreeSans9pt7b);
matrix.setBrightness(5);
matrix.setTextColor(colors[0]);
tiempo = millis();
int x = matrix.width();
int pass = 1;
char buffer[5];
matrix.setCursor(0, 13);
if(x < 13)
x = matrix.width();
// if(++pass >= 3) pass = 0;
// matrix.setTextColor(colors[pass]);
if (millis() - start > 100UL) {
//if(++pass >= 3) pass = 0;
//matrix.setTextColor(colors[pass]);
matrix.fillScreen(0);
tiempo = millis()/1000;
sprintf(buffer,"%4d", tiempo);
matrix.print(buffer);
start = millis();
matrix.show();
Thank you
