hi. i am trying to uplode this code to nodemcu:
while(!Serial) { delay(100); }
Serial.println("Hello!");
but "hello" didnot print.
where is the problem:
i reset also then nodemcu but not work.
The nodeMCU is sending you something. Maybe it is not running your sketch and is trying to tell you why. I would try some of the other common baud rates on Serial Monitor and reset the nodeMCU to see if the data i readable at any other baud rate. Start with 9600 which seems to be a common default.
I just ran it using the NodeMCU-32S board and it ran fine.
Edit: John, I'll bet he doesn't have the baud rate set to the correct number in the Monitor.
johnwasser:
i run it to baund 74882 and get this:
" ets Jan 8 2013,rst cause:2, boot mode:(1,6) "
i change pin gpio 2 to 4 and it worked and it print hello finally.
i read this:
Have you connected some new devices to GPIO 0, 2 or 15? They control the boot-mode of the ESP and if some device you've connected pulls the wrong pin high or low it'll change boot-mode from normal to something else. See https://zoetrope.io/tech-blog/esp8266-bootloader-modes-and-gpio-state-startup
econjack:
If you look at the screen capture you will see 115200 both in Serial.begin() and the Serial Monitor setting. If those two values were different I would have pointed that out. That is why I suggested other baud rates to see if there was a message from something other than the sketch.
