I have problem with Arduino Mega and Ethernet Shield.
When I am using Arduino Mega without Ethernet Shield I can use pins from 23 to 49 as OUTPUT pins without any problem. I declare in setup HIGH state and use LOW state to control relays.
But when I connect Ethernet Shield only pins from 23 to 29 work. Pins from 30 to 49 are not.
I tried two different shilds based on W5100 and W5500 but it still does not work.
Where may be a problem?
Thanks in advance for replays.
I suggest you read the datasheets of both the Mega and the shield. Maybe even look at the schematics. I don't think I ever saw a shield that didn't use some pins of the board it was attached to.
Just a question. Where does the shield in your photo connect to the SPI of the Mega? I don't see the central SPI (ICSP) header on the shield.
Just change pins, they must be reserved or something when the shield is on.
Thank You for Your help. I solved a problem which was hidden in code. There was a bug which was changing pin numbers.
