Problem with PlatformIO avr-debugger on Arduino Mega2560
Hello
I fired all the Serials. of my project but I still get this error message when compiling:
*  Executing task in folder VS_Aurore_V34: C:\Users\utilisateur\.platformio\penv\Scripts\platformio.exe run
Processing megaatmega2560 (platform: atmelavr; board: megaatmega2560; framework: arduino)
------------------------------------------------------------------------------------------------------Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/atmelavr/megaatmega2560.html
PLATFORM: Atmel AVR (5.0.0) > Arduino Mega or Mega 2560 ATmega2560 (Mega 2560)
HARDWARE: ATMEGA2560 16MHz, 8KB RAM, 248KB Flash
DEBUG: Current (avr-stub) External (avr-stub, simavr)
PACKAGES:
 - framework-arduino-avr @ 5.2.0
 - toolchain-atmelavr @ 1.70300.191015 (7.3.0)
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 13 compatible libraries
Scanning dependencies...
Dependency Graph
|-- avr-debugger @ 1.5.0
|-- EEPROM @ 2.0
|-- LiquidCrystal_I2C
|-- OneWire @ 2.3.8
|-- RTC @ 2.4.3
|-- SD @ 1.2.4
|-- SPI @ 1.0
|-- Wire @ 1.0
Building in release mode
Linking .pio\build\megaatmega2560\firmware.elf
HardwareSerial0.cpp.o (symbol from plugin): In function `Serial':
(.text+0x0): multiple definition of `__vector_25'
avr8-stub.c.o (symbol from plugin):(.text+0x0): first defined here
collect2.exe: error: ld returned 1 exit status
*** [.pio\build\megaatmega2560\firmware.elf] Error 1
===================================== [FAILED] Took 6.93 seconds =====================================
 *  The terminal process "C:\Users\utilisateur\.platformio\penv\Scripts\platformio.exe 'run'" terminated with exit code: 1.
 *  Terminal will be reused by tasks, press any key to close it.
Can you help me ?
Thanks!
Since we can't see your code we can only guess, but that error is saying you are trying to declare a variable twice. This is usually what happens if you don't use include guards.
Thanks, I will try it tomorrow
Sorry, I accidentally activated the flag on your last message and it disappeared.
