problem with serial.println()
I am trying to use serial.println() on my Arduino Uno using the Arduino IDE with some difficulty. I am inputting numbers using the serial monitor, but it is not outputting the correct numbers.
Arduino code:
int a= Serial.read();
Serial.println(a);
The Arduino website says I should be getting the following outputs:
Serial.print(78) gives "78"
Serial.print(1.23456) gives "1.23"
Serial.print('N') gives "N"
Serial.print("Hello world.") gives "Hello world."
However, when I input the following, I get:
55
10
49
50
52
54
39
39
34
Can you tell me what the problem is, and how to fix it?
lcr2139:
Not without seeing your code...
You might want to look at an ASCII table. Perhaps a clue will appear.
