To resume my project I made a controller that activate a motor.
At first I was driving my relay directly from Arduino board. but this was a bad idea has relay use 73ma, way over the rating of the Arduino board.
Now that I busted my card I building another one but added an Optocoupler. Strangely even on a basic test I can't seem to activate the optocoupler.
I use an Arduino Duemilanove, a 470 ohms resistor, an optocoupler 4n35. The resistance should give around 8.5ma to the led. My Relay are goodsky rs-ss-105d
Here the simplest test I could have thanked and it still doesn't work. Even using multi-meter to test continuity doesn't seem to work between collector and emitter. I hope someone could explain me why it doesn't work.
Optos usually have a parameter called a Current Transfer Ratio (CTR) which is expressed in %. 40 or 50% is common but I've seen them as low as 20% meaning you put 10mA in you get 2mA out. Sometimes the range is huge 50-600% for a K817 for example.
I can't see that parameter on the 4n35 data sheet so I don't know what it is. Presumably you could calc it from the other parameters.
Anyway the best and simplest option is to buy a transistor.
