Problem with Software Serial Library?
I have been trying to compile this example code from arduino 1.0.6 ide
  Software serial multple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 10 (connect to TX of other device)
 * TX is digital pin 11 (connect to RX of other device)
 Note:
 Not all pins on the Mega and Mega 2560 support change interrupts,
 so only the following can be used for RX:
 10, 11, 12, 13, 50, 51, 52, 53, 62, 63, 64, 65, 66, 67, 68, 69
 Not all pins on the Leonardo support change interrupts,
 8, 9, 10, 11, 14 (MISO), 15 (SCK), 16 (MOSI).
 created back in the mists of time
 modified 25 May 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
  Serial.begin(57600);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
  // set the data rate for the SoftwareSerial port
  mySerial.begin(4800);
  mySerial.println("Hello, world?");
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
But it doesn't compile the error it shows is like
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::begin(long int)':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:399: error: 'PCICR' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK2' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:402: error: 'PCMSK1' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp: In member function 'void SoftwareSerial::end()':
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK2' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK0' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\SoftwareSerial\SoftwareSerial.cpp:417: error: 'PCMSK1' was not declared in this scope
Not only this, even if I try to code any other program using software serial library error is of same manner, tried restarting the pc, tried uninstalling and installing the arduino ide, tried with arduino 1.0.5, but of no avail, any help would be a great relief.
Thanks
I am sure that it will be no consolation to you but it compiles OK for me using 1.0.5
Have you done a Google search for the error messages ?
Yeah, I tried in different pc, but of no avail
I even tried with googling the errors and many people have received the errors but no proper solution
Finally got the answer, code doesn't compile when i choose Arduino NG or older w Atmega 8, it compiles only when you choose Arduino Uno,
I wonder why in the world, that this ide doesn't compile when we choose a incompatible board.
Anyways, Thanks a ton
Those constants that it can't find are hardware-specific. What I wonder is why you think that the compiler can perform magic and make the code needed to run on incompatible hardware.
There could be a clue there.
