Problem with SPI with a LSM9DS0 IMU and a MCP4131 Digital Potentiometer
Individually, I have made both work the way i wanted them to but when trying to make them both slaves, the Potentiometer stops the IMU from talking to the arduino properly.
you can find both products here: SparkFun 9 Degrees of Freedom IMU Breakout - LSM9DS0 - SEN-12636 - SparkFun Electronics
Digital Potentiometer - 10K - COM-10613 - SparkFun Electronics
Here is a link to the hook up guide i used:LSM9DS0 Hookup Guide - SparkFun Learn
Here are links to the Datasheets:https://cdn.sparkfun.com/assets/f/6/1/f/0/LSM9DS0.pdf
Hi mduffy
Please post a diagram of how you have the two devices connected to the Arduino.
Also post your code so we can take a look (use the code tags - the "#" button above the row of smileys). And say more about exactly what happens (or not) when you run the program ...
Regards
Ray
the only additions are power to the potentiometer and the SCL and SDI/SDO lines connecting to pins 13 and 11 respectively
when running the IMU alone i get a response like this
G: -0.63, -243.67, -244.16
A: -1.99, -1.27, 2.00
M: 1.86, -1.89, -1.95
Heading: 44.50
Pitch, Roll: -20.73, -11.93
after i connect the SCL and SDI/SDO lines to the potentiometer i get a response like this
G: -0.01, -0.01, -0.01
A: -0.00, -0.00, -0.00
M: -0.00, -0.00, -0.00
Heading: -45.00
Pitch, Roll: -45.00, -45.00
here is the script i am using, I have not yet even included any pieces of code that interact with the potentiometer i have only connected the pins
// The SFE_LSM9DS0 requires both the SPI and Wire libraries.
// Unfortunately, you'll need to include both in the Arduino
// sketch, before including the SFE_LSM9DS0 library.
#include <SPI.h> // Included for SFE_LSM9DS0 library
#include <Wire.h>
#include <SFE_LSM9DS0.h>
// Example I2C Setup //
// Comment out this section if you're using SPI
// SDO_XM and SDO_G are both grounded, so our addresses are:
#define LSM9DS0_XM  0x1D // Would be 0x1E if SDO_XM is LOW
#define LSM9DS0_G   0x6B // Would be 0x6A if SDO_G is LOW
// Create an instance of the LSM9DS0 library called `dof` the
// parameters for this constructor are:
// [SPI or I2C Mode declaration],[gyro I2C address],[xm I2C add.]
LSM9DS0 dof(MODE_I2C, LSM9DS0_G, LSM9DS0_XM);
// Example SPI Setup //
// Uncomment this section if you're using SPI
#define LSM9DS0_CSG  9  // CSG connected to Arduino pin 9
#define LSM9DS0_CSXM 10 // CSXM connected to Arduino pin 10
LSM9DS0 dof(MODE_SPI, LSM9DS0_CSG, LSM9DS0_CSXM);
const int CSG  =9;
const int CSXM =10;
const int slaveSelectPin = 6;
// Do you want to print calculated values or raw ADC ticks read
// from the sensor? Comment out ONE of the two #defines below
// to pick:
#define PRINT_CALCULATED
//#define PRINT_RAW
#define PRINT_SPEED 500 // 500 ms between prints
  Serial.begin(9600); // Start serial at 115200 bps
  // Use the begin() function to initialize the LSM9DS0 library.
  // You can either call it with no parameters (the easy way):
  uint16_t status = dof.begin();
  // Or call it with declarations for sensor scales and data rates:
  //uint16_t status = dof.begin(dof.G_SCALE_2000DPS,
  //                            dof.A_SCALE_6G, dof.M_SCALE_2GS);
  // begin() returns a 16-bit value which includes both the gyro
  // and accelerometers WHO_AM_I response. You can check this to
  // make sure communication was successful.
  Serial.print("LSM9DS0 WHO_AM_I's returned: 0x");
  Serial.println(status, HEX);
  Serial.println("Should be 0x49D4");
  printGyro();  // Print "G: gx, gy, gz"
  printAccel(); // Print "A: ax, ay, az"
  printMag();   // Print "M: mx, my, mz"
  // Print the heading and orientation for fun!
  printHeading((float) dof.mx, (float) dof.my);
  printOrientation(dof.calcAccel(dof.ax), dof.calcAccel(dof.ay),
                   dof.calcAccel(dof.az));
  delay(PRINT_SPEED);
void printGyro()
  // To read from the gyroscope, you must first call the
  // readGyro() function. When this exits, it'll update the
  // gx, gy, and gz variables with the most current data.
  dof.readGyro();
  // Now we can use the gx, gy, and gz variables as we please.
  // Either print them as raw ADC values, or calculated in DPS.
  Serial.print("G: ");
#ifdef PRINT_CALCULATED
  // If you want to print calculated values, you can use the
  // calcGyro helper function to convert a raw ADC value to
  // DPS. Give the function the value that you want to convert.
  Serial.print(dof.calcGyro(dof.gx), 2);
  Serial.print(", ");
  Serial.print(dof.calcGyro(dof.gy), 2);
  Serial.print(", ");
  Serial.println(dof.calcGyro(dof.gz), 2);
#elif defined PRINT_RAW
  Serial.print(dof.gx);
  Serial.print(", ");
  Serial.print(dof.gy);
  Serial.print(", ");
  Serial.println(dof.gz);
#endif
void printAccel()
  // To read from the accelerometer, you must first call the
  // readAccel() function. When this exits, it'll update the
  // ax, ay, and az variables with the most current data.
  dof.readAccel();
  // Now we can use the ax, ay, and az variables as we please.
  // Either print them as raw ADC values, or calculated in g's.
  Serial.print("A: ");
  // calcAccel helper function to convert a raw ADC value to
  // g's. Give the function the value that you want to convert.
  Serial.print(dof.calcAccel(dof.ax), 2);
  Serial.print(", ");
  Serial.print(dof.calcAccel(dof.ay), 2);
  Serial.print(", ");
  Serial.println(dof.calcAccel(dof.az), 2);
  Serial.print(dof.ax);
  Serial.print(", ");
  Serial.print(dof.ay);
  Serial.print(", ");
  Serial.println(dof.az);
#endif
void printMag()
  // To read from the magnetometer, you must first call the
  // readMag() function. When this exits, it'll update the
  // mx, my, and mz variables with the most current data.
  dof.readMag();
  // Now we can use the mx, my, and mz variables as we please.
  // Either print them as raw ADC values, or calculated in Gauss.
  Serial.print("M: ");
  // calcMag helper function to convert a raw ADC value to
  // Gauss. Give the function the value that you want to convert.
  Serial.print(dof.calcMag(dof.mx), 2);
  Serial.print(", ");
  Serial.print(dof.calcMag(dof.my), 2);
  Serial.print(", ");
  Serial.println(dof.calcMag(dof.mz), 2);
  Serial.print(dof.mx);
  Serial.print(", ");
  Serial.print(dof.my);
  Serial.print(", ");
  Serial.println(dof.mz);
#endif
// Here's a fun function to calculate your heading, using Earth's
// magnetic field.
// It only works if the sensor is flat (z-axis normal to Earth).
// Additionally, you may need to add or subtract a declination
// angle to get the heading normalized to your location.
// See: http://www.ngdc.noaa.gov/geomag/declination.shtml
void printHeading(float hx, float hy)
  float heading;
  if (hy > 0)
    heading = 90 - (atan(hx / hy) * (180 / PI));
  else if (hy < 0)
    heading = - (atan(hx / hy) * (180 / PI));
  else // hy = 0
    if (hx < 0) heading = 180;
    else heading = 0;
  Serial.print("Heading: ");
  Serial.println(heading, 2);
// Another fun function that does calculations based on the
// acclerometer data. This function will print your LSM9DS0's
// orientation -- it's roll and pitch angles.
void printOrientation(float x, float y, float z)
  float pitch, roll;
  pitch = atan2(x, sqrt(y * y) + (z * z));
  roll = atan2(y, sqrt(x * x) + (z * z));
  pitch *= 180.0 / PI;
  roll *= 180.0 / PI;
  Serial.print("Pitch, Roll: ");
  Serial.print(pitch, 2);
  Serial.print(", ");
  Serial.println(roll, 2);
Thanks for those.
The GND wire from breadboad to Arduino seems to be floating. I assume it connects to the GND terminal just above pin 13?
Can you confirm something about the code you posted. Is this the version that works if just the IMU connected? Or did you make any changes in advance of connecting the potentiometer? Reason for asking is that it seems to be configured (comment out / not comment out) for talking to the IMU via SPI, whereas your circuit is set up for I2C.
const int CSG  =9;
const int CSXM =10;
// to pick:
//#define PRINT_RAW
actually i have a few extra things connected
If you're using SPI, here is an example hardware setup:
    LSM9DS0 --------- Arduino
          CSG -------------- 9
          CSXM ------------- 10
          SDOG ------------- 12
          SDOXM ------------ 12 (tied to SDOG)
          SCL -------------- 13
          SDA -------------- 11
          VDD -------------- 3.3V
          GND -------------- GND
I accidentally deleted it because i hit the character limit in the last post
the grounds i am using are next to the 3.3V and 5V( not a real reason why im using two but i did not think it would matter)
The IMU can work over I2C, and that was what your original diagram showed, with just SDA, SCL and power connections. And I thought you had it working that way?
So I can't see why you need to switch the IMU to SPI bus. Can't you leave it working over I2C and then add the potentiometer via SPI?
It actually never worked over I2C but it seemed that there was a rubber coating over one of the new wires so you were right the ground was floating.
Sorry that was a bit of a waste of your time, I will be careful to check for obvious stuff like that next time
cheers
