Problem with STM32 board (HiWonder Le Arm 6DOF) with FTDI FT232RL USB to TTL with
Hi, i want to upload a simple standard script to my Robot arm to test it, i want to use it with Arduino IDE and make it move.
Everytime i do something i receive this message:
Sketch uses 11176 bytes (8%) of program storage space. Maximum is 131072 bytes.
Global variables use 1432 bytes (6%) of dynamic memory, leaving 19048 bytes for local variables. Maximum is 20480 bytes.
"C:\Users\marti\AppData\Local\Arduino15\packages\stm32duino\tools\stm32tools\2022.9.26/win/serial_upload.bat" COM5 {upload.altID} {upload.usbID} "C:\Users\marti\AppData\Local\arduino\sketches\8CAE406C948BEABD051C58AEE819214F/Blink.ino.bin"
stm32flash 0.4
http://stm32flash.googlecode.com/
Using Parser : Raw BINARY
Interface serial_w32: 115200 8E1
Failed to init device.
These are my settings:
This is my setup in "real-life"
The standard "blink" script i am using: to test
  Blink
  Turns an LED on for one second, then off for one second, repeatedly.
  Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
  it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
  the correct LED pin independent of which board is used.
  If you want to know what pin the on-board LED is connected to on your Arduino
  model, check the Technical Specs of your board at:
  https://docs.arduino.cc/hardware/
  modified 8 May 2014
  by Scott Fitzgerald
  modified 2 Sep 2016
  by Arturo Guadalupi
  modified 8 Sep 2016
  by Colby Newman
ik zi
  This example code is in the public domain.
  https://docs.arduino.cc/built-in-examples/basics/Blink/
// the setup function runs once when you press reset or power the board
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(LED_BUILTIN, HIGH);  // turn the LED on (HIGH is the voltage level)
  delay(1000);                      // wait for a second
  digitalWrite(LED_BUILTIN, LOW);   // turn the LED off by making the voltage LOW
I really hope someone can help me out with this! Ive tried everything and i just cant solve this...
Kind regards,
Martijn
There is a known issue with serial monitor / plotter and FTDI adapters in IDE 2.x. If the serial monitor (or serial plotter) is open it results in failed uploads. Might that be the case for you?
I think i have to Boot it somehow but i dont know why (just like to boot a ESP32 CAM to put something on it)...
You have any idea?
Unfortunately not. I happily live in an AVR world so have no experience with any other boards.
Ah okey, thanks for your answer!
