Hi all, I am trying to build a GPS tracker using an adafruit FONA (cell phone/gps module) but I can't seem to convert the latitude and longitude from a floating integer to something I can text. I'm not great at coding and most of this is hacked together from example codes, but I keep getting the error
"invalid conversion from 'char' to 'char*' [-fpermissive]"
Messages apparently can only be one character?? A little confused
This is an example for our Adafruit FONA Cellular Module (modified slightly by mrwillcreates)
Designed specifically to work with the Adafruit FONA
----> Adafruit FONA - Mini Cellular GSM Breakout uFL Version : ID 1946 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits
----> Adafruit FONA - Mini Cellular GSM Breakout - SMA Version [v1] : ID 1963 : $44.95 : Adafruit Industries, Unique & fun DIY electronics and kits
----> Adafruit FONA 800 Shield - Voice/Data Cellular GSM for Arduino : ID 2468 : $39.95 : Adafruit Industries, Unique & fun DIY electronics and kits
----> Adafruit FONA 808 - Mini Cellular GSM + GPS Breakout : ID 2542 : $49.95 : Adafruit Industries, Unique & fun DIY electronics and kits
These cellular modules use TTL Serial to communicate, 2 pins are
required to interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
THIS CODE IS STILL IN PROGRESS!
This code will receive an SMS and send location data back to the same number
For use with FONA 800 & 808, not 3G
#include "Adafruit_FONA.h"
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// this is a large buffer for replies
char replybuffer[255];
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
// HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
while (!Serial);
// make it slow so its easy to read!
fonaSerial->begin(4800);
if (! fona.begin(*fonaSerial)) {
Serial.println(F("Couldn't find FONA"));
while(1);
// Print SIM card IMEI number.
char imei[15] = {0}; // MUST use a 16 character buffer for IMEI!
uint8_t imeiLen = fona.getIMEI(imei);
if (imeiLen > 0) {
char fonaInBuffer[64]; //for notifications from the FONA
float latitude, longitude, speed_kph, heading, speed_mph, altitude;
// if you ask for an altitude reading, getGPS will return false if there isn't a 3D fix
boolean gps_success = fona.getGPS(&latitude, &longitude, &speed_kph, &heading, &altitude);
char* bufPtr = fonaInBuffer; //handy buffer pointer
if (fona.available()) //any data available from the FONA?
int slot = 0; //this will be the slot number of the SMS
int charCount = 0;
//Read the notification into fonaInBuffer
do {
*bufPtr = fona.read();
Serial.write(*bufPtr);
delay(1);
} while ((*bufPtr++ != '\n') && (fona.available()) && (++charCount < (sizeof(fonaInBuffer)-1)));
//Add a terminal NULL to the notification string
*bufPtr = 0;
//Scan the notification string for an SMS received notification.
// If it's an SMS message, we'll get the slot number in 'slot'
if (1 == sscanf(fonaInBuffer, "+CMTI: "SM",%d", &slot)) {
char callerIDbuffer[32]; //we'll store the SMS sender number in here
// Retrieve SMS sender address/phone number.
if (! fona.getSMSSender(slot, callerIDbuffer, 31)) {
//Send back an automatic response
//Convert floating int to char
char longitude;
if (!fona.sendSMS(callerIDbuffer, longitude)) {
Serial.println(F("Failed"));
Serial.println(F("Sent!"));
// delete the original msg after it is processed
// otherwise, we will fill up all the slots
// and then we won't be able to receive SMS anymore
if (fona.deleteSMS(slot)) {
Serial.println(F("OK!"));
Serial.println(F("Couldn't delete"));
