Problem with the SparkFun LIS3DH SEN-13963
Hi guys,
So I've successfully hooked up my hardware. Following the diagram on SparkFun's Hookup Guide
And I've successfully installed the Library and Compiled the code and uploaded. (Also from SparkFun)
But once I did it, and successfully pulled up the Serial Monitor, my x,y, and z output values just kept producing a -0.0001. Any suggestions?
I've checked and triple checked that I did not wire the hardware wrongly.
Chris
If you did the wiring as in the attached image you have a short circuit on 3V3.
Also the level converter on that picture is not bidirectional level converter as SCLK is a signal from the Arduino to the sensor and not the other way around.
