Problem with uploading the sketch to the ESP32-CAM using Arduino Uno
Hi dears, I'm trying to upload builtin example "CameraWebServer.ino" via Arduino Uno , but during upload after pressing RST button on ESP32 board I receive following error:
Compilation complete.
esptool.py v3.0-dev
Serial port COM3
Connecting.......
Chip is ESP32-D0WDQ6-V3 (revision 3)
Features: WiFi, BT, Dual Core, 240MHz, VRef calibration in efuse, Coding Scheme None
Crystal is 40MHz
MAC: 30:c6:f7:1f:f7:00
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
A fatal error occurred: Timed out waiting for packet header
Upload error: Failed uploading: uploading error: exit status 2
Where did I go wrong?
Welcome to the forum
How exactly are the two systems connected and how have you dealt with the fact that the Uno is a 5V device whilst the ESP32 is a 3.3V device ?
Have you grounded the ESP32 GPIO pin when trying to upload the code ?
Hi, thanks for your reply
1- My connection is as below:
  • Arduino GND & 5Volt connected to ESP32-CAM POW pins (GND & 5V)
  • Arduino RESET pin connected to ESP32-CAM GND
  • a jumper connected to GND & GPIO 0 of ESP32-CAM
  • Arduino RX & TX pins connected respectively to U0RXD & U0TXD of ESP32-CAM
    as described in link: Using ESP32 cam with arduino
2- as shown in ESP32-CAM pinout, POW pins of board has 5Volt & GND power supply
3- Yes, I have grounded GPIO 0 pin during upload to force ESP32 board to go to FLASH mode during upload process.
4- as described in link below, When I start to see "Connecting....." in the debugging window , I pressed the ESP32-CAM on-board RST button.
ESP32-CAM Video Streaming and Face Recognition with Arduino IDE
