I'm trying to set up a REST api on my arduino uno + cc3000 wifi shield. I am following this tutorial, but I am stuck. I am unable to get any response from the arduino either when visiting arduino.local or by trying to access the IP address directly in the browser. I realized that my hardware (cc3000 shield) is different than the breakout board used in the tutorial.. and I'm wondering if this might cause the problem, as if so, what I should do to troubleshoot the issue. I have a fairly near deadline to get the prototype I'm working on functioning, so I've ordered the breakout board version of the cc3000 as well, and it should be arriving tomorrow. I would love some guidance! Here is the code I am using (just the CC3000-WIFI example in the aREST library).. I've tried running this from the IDE versions 1.57 and 1.58, as well as Arduino v. 1.06 all on Mac osx yosemit
This a simple example of the aREST Library for Arduino (Uno/Mega/Due/Teensy)
using the CC3000 WiFi chip. See the README file for more details.
Written in 2014 by Marco Schwartz under a GPL license.
// Import required libraries
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include <CC3000_MDNS.h>
#include <aREST.h>
#include <avr/wdt.h>
// These are the pins for the CC3000 chip if you are using a breakout board
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// Create CC3000 instance
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
SPI_CLOCK_DIV2);
// Create aREST instance
aREST rest = aREST();
// Your WiFi SSID and password
#define WLAN_SSID "yourSSID"
#define WLAN_PASS "yourPassword"
#define WLAN_SECURITY WLAN_SEC_WPA2
// The port to listen for incoming TCP connections
#define LISTEN_PORT 80
// Server instance
Adafruit_CC3000_Server restServer(LISTEN_PORT);
// DNS responder instance
MDNSResponder mdns;
// Variables to be exposed to the API
int temperature;
int humidity;
void setup(void)
// Start Serial
// Init variables and expose them to REST API
temperature = 24;
humidity = 40;
rest.variable("temperature",&temperature);
rest.variable("humidity",&humidity);
// Function to be exposed
rest.function("led",ledControl);
// Give name and ID to device
rest.set_id("008");
rest.set_name("mighty_cat");
// Set up CC3000 and get connected to the wireless network.
if (!cc3000.begin())
while(1);
if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
while(1);
while (!cc3000.checkDHCP())
delay(100);
// Print CC3000 IP address. Enable if mDNS doesn't work
//while (! displayConnectionDetails()) {
// delay(1000);
// Start multicast DNS responder
if (!mdns.begin("arduino", cc3000)) {
while(1);
// Start server
restServer.begin();
Serial.println(F("Listening for connections..."));
// Enable watchdog
wdt_enable(WDTO_4S);
// Handle any multicast DNS requests
mdns.update();
// Handle REST calls
Adafruit_CC3000_ClientRef client = restServer.available();
rest.handle(client);
wdt_reset();
// Check connection, reset if connection is lost
if(!cc3000.checkConnected()){while(1){}}
wdt_reset();
// Print connection details of the CC3000 chip
bool displayConnectionDetails(void)
uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
Serial.println(F("Unable to retrieve the IP Address!\r\n"));
return false;
Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
return true;
// Custom function accessible by the API
int ledControl(String command) {
// Get state from command
int state = command.toInt();
digitalWrite(6,state);
return 1;
