How do I make a working Arduino using the REST API?
Hi! I’m new to using the Arduino and programming in general, but for a small project, I want to turn on an LED wirelessly using the Arduino Uno and a CC3000 WiFi Shield. I also want to incorporate REST API into it, but I’m not sure how. I've been looking around the internet, but I can’t seem to find any tutorials that specifically work with the Arduino Uno and CC3000 Wifi Shield. I have an Arduino Uno, CC3000 WiFi Shield, jumper wires, 2 LED, a breadboard, and two 220 ohm resistors. I've soldered the WiFi Shield and connected it to the Arduino Uno. I’m still a beginner with all of this so any help would be much appreciated. Thanks!
Also, do you know any codes that are compatible with the REST API that I can use to turn on and off the LED?
There are so many project with cc3000, i guess you dint search a lot.. some quick results:
http://www.openhomeautomation.net/arduino-wifi-cc3000/
Thank you for the response, zaxarias. But I have already checked those websites, and they have served little to no use.
So you want someone to give you the code for your project ?
Without even trying to learn some basics..
Well good luck with that !!! :smiley: :smiley: :smiley:
I have learned the basics of Arduino, such as making the Arduino -- without the WiFi shield -- blink and fade: in fact, I have managed to make the Arduino have a single LED both blink then fade, vice versa, and then at the same time. I have tried learning the basics, but I am stumped at how to make the WiFi shield work at all. Do I want someone to give me code for my project? Not exactly, I want an example, just like how the IDE has examples of blinking, fading, and sensors. It would help if someone gave me a foundation to play around with and work on, for I simply do not understand what makes the code work through the REST API. I just want the Arduino to blink via WiFi.
Flair:
I think the links posted above can really help you make it work..
Here is a nice tutorial too https://learn.adafruit.com/downloads/pdf/adafruit-cc3000-wifi.pdf
Thank you for the tutorial, but that WiFi shield does not quite match mine. My shield are missing a few pins in the tutorial you posted, so the code does not work with the hardware I have.
Sorry but i still believe you don't try much...
Where exactly is your problem... You can 't make the wiring?
I have gotten the wiring down, but now the Arduino either stays on the "Listening for connections..." forever or the serial monitor prints four (sometimes eight) unreadable characters (or spaces).
What software are you using to communicate with arduino ? Are you sure the wiring is OK ? maybe it would help if you showed a photo of the wiring.
