Volevo ampliare il tutorial che ho fatto con l' LM35 e far fare a pachube da datalogger per le temperature perchè quando l'ho provato tempo fa mi era parso semplice, però questa volta Arduino+Ethernet Shield mi manda in palla i router (di Alice) e non riesco a capire il perchè.
Se qualcuno ha qualche dritta da darmi ne sarei felicissimo!!
Posto anche il codice:
Tab Pachube_ethernet_input_output:
* This code, which assumes you're using the official Arduino Ethernet shield,
* updates a Pachube feed with your analog-in values and grabs values from a Pachube
* feed - basically it enables you to have both "local" and "remote" sensors.
* Tested with Arduino 14
* Pachube is www.pachube.com - connect, tag and share real time sensor data
* code by usman (www.haque.co.uk), may 2009
* copy, distribute, whatever, as you like.
* v1.1 - added User-Agent & fixed HTTP parser for new Pachube headers
* and check millis() for when it wraps around
#include <Ethernet.h>
#include <string.h>
#undef int() // needed by arduino 0011 to allow use of stdio
#include <stdio.h> // for function sprintf
#define LM35_TEMP 0 // Pin analogico 0
#define LM35_REF 1 // Pin analogico 1
#define SHARE_FEED_ID 2413 // this is your Pachube feed ID that you want to share to
#define REMOTE_FEED_ID 256 // this is the ID of the remote Pachube feed that you want to connect to
#define REMOTE_FEED_DATASTREAMS 4 // make sure that remoteSensor array is big enough to fit all the remote data streams
#define UPDATE_INTERVAL 10000 // if the connection is good wait 10 seconds before updating again - should not be less than 5
#define RESET_INTERVAL 10000 // if connection fails/resets wait 10 seconds before trying again - should not be less than 5
#define PACHUBE_API_KEY "il mio API KEY" // fill in your API key
byte mac[] = { 0xFE, 0xDE, 0xAA, 0xED, 0xEF, 0x85 }; // make sure this is unique on your network
byte ip[] = { 192, 168, 1, 144 }; // no DHCP so we set our own IP address
byte remoteServer[] = { 209,40,205,190 }; // pachube.com
float remoteSensor[REMOTE_FEED_DATASTREAMS]; // we know that feed 256 has floats - this might need changing for feeds without floats
Serial.begin(57600);
setupEthernet();
// call 'pachube_in_out' at the beginning of the loop, handles timing, requesting
// and reading. use serial monitor to view debug messages
pachube_in_out();
}//Loop
Tab pachube_functions:
char pachube_data[70];
boolean found_status_200 = false;
boolean found_session_id = false;
boolean found_CSV = false;
char *found;
unsigned int successes = 0;
unsigned int failures = 0;
boolean ready_to_update = true;
boolean reading_pachube = false;
boolean request_pause = false;
boolean found_content = false;
unsigned long last_connect;
int content_length;
float temperatura; // variabile in cui viene salvata la temperatura in gradi centigradi
float prev_temperatura = 0; // temperatura precendente
int ref; // valore della tensione di riferimento dei due diodi
int ref_medio = 0; // valore della tensione di riferimento medio
int sensoreTemperatura; // valore di tensione letto dal pin OUT del sensore
int sensoreTemperatura_medio = 0; // valore sensoreTemperatura medio
int cont; //contatore usato per ottenere un valore medio
void pachube_in_out(){
if (millis() < last_connect) last_connect = millis();
if (request_pause){
if ((millis() - last_connect) > interval){
found_CSV = false;
//Serial.print("Ready to connect: ");
//Serial.println(millis());
if (ready_to_update){
Serial.println("Connecting...");
if (localClient.connect()) {
// here we assign comma-separated values to 'data', which will update Pachube datastreams
// we use all the analog-in values, but could of course use anything else millis(), digital
// inputs, etc. . i also like to keep track of successful and failed connection
// attempts, sometimes useful for determining whether there are major problems.
// vengono sommati 10 valori di temperatura per poi farne la media
for( cont = 0; cont < 10; cont++)
sensoreTemperatura = analogRead(LM35_TEMP); // lettura della tensione del pin OUT LM35
sensoreTemperatura_medio += sensoreTemperatura; //sommatoria dei valori
ref = analogRead(LM35_REF); // lettura della tensione di riferimento
ref_medio += ref; // sommatoria dei valori
// delay(500); // intervallo di campionamento
//la lettura durera' 10 (numero di camoioni) x 500ms (intervallo tra due campioni) = 5000ms
if(cont == 10) // quando ho sommato i dieci valori campionati si esegue:
cont = 0; // azzeramento contatore, per far ripartire il successivo campionamento
// media della sommatoria dei dieci valori campionati di ref e sensoreTemperatura
sensoreTemperatura_medio = sensoreTemperatura_medio / 10;
ref_medio = ref_medio / 10;
// conversione dei valori medi misurati in una temperatura in gradi centigradi
temperatura = (sensoreTemperatura_medio - ref_medio) * 100/2.56;
temperatura = temperatura * 5/1024;
// valore di temperatura che verra' mostrato quando si e' in fase di campionamento
//e non c'e' una temperatura disponibile
prev_temperatura = temperatura;
// stampa su seriale dei due valori medi
// Serial.print(" ref_medio: ");
//Serial.print(ref_medio);
//Serial.print(" temp_medio: ");
//Serial.print(sensoreTemperatura_medio);
// prima di un successiva acquisizione e media questi valori vanno azzerati
ref_medio = 0;
else{
temperatura = prev_temperatura;
// stampa su seriale della temperatura ottenuta in gradi centigradi
//Serial.print(" gradi: ");
//Serial.println(temperatura);
sprintf(pachube_data,"%f,%d,%d", temperatura , successes + 1, failures);
content_length = strlen(pachube_data);
... il resto è uguale
In pratica sulla seriale vedo :
Connecting... connection failed
quindi non riesce mai ad entrare nell' " if (localClient.connect()) { "
che si trova dopo l'istruzion " Serial.println("Connecting..."); "
