hola, soy nuevo en este foro, me encontre con un problema al instalar el programa arduino en mac, lo que pasa es que tan solo en verificar lanza error el arduino, no hay problema con la salida en el com ni nada de eso, lo que aparece es todo esto
Opciones de compilación cambiadas, reconstruyendo todo
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: dlopen(/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../libexec/gcc/avr/4.9.2/liblto_plugin.so, 2): Symbol not found: _environ
Referenced from: /Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../libexec/gcc/avr/4.9.2/liblto_plugin.so
Expected in: /usr/lib/libSystem.B.dylib
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/WInterrupts.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: WInterrupts.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/hooks.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: hooks.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/wiring.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: wiring.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/wiring_analog.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: wiring_analog.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/wiring_digital.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: wiring_digital.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/wiring_pulse.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: wiring_pulse.c.o: plugin needed to handle lto object
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/../lib/gcc/avr/4.9.2/../../../../avr/bin/ar: core/wiring_shift.c.o: plugin needed to handle lto object
collect2: error: ld returned 1 exit status
exit status 1
Error compilación en tarjeta Arduino Uno
ese es el error , es mas largo pero no me deja subirlo, si alguien puede ayudar le estaria agradecido.
