problema DHT11 timeout error
Ciao tutti,
ho comprato tempo fa su amazon il DHT11 della sunfounder link.
All'inizio tutto funzionava ma adesso si presenta l'errore "timeout error".
Ho letto alcune discussioni dove si diceva che probabilmente fosse rotto link è così?
Esiste la possibilità di verificare questo evento?
Inserisco il codice che ho utilizzato fino ad ora.
 FILE:    Humidity.30MAG16
 TAG:     DHT11, time out error
 PURPOSE: Humidity test sketch for Arduino
 PROBES:  DHT11
 VERSION:
 DISPLAY: NC
 COMFORT: HR 45%, T 23°C
 AUTHOR:  Antonio Cannavale
 DHT11 connected to a Arduino as follow:
 GND -> GND
 VCC -> +5V
 SIG -> Digital pin
#include <dht11.h> // Include DHT11 library:
dht11 DHT; // Store an instance of the DHT11 sensor:
#define DHT11_PIN 2 // Define input at digital pin:
boolean DEBUG = true; // Set to true to print status messages to the serial:
// The setup function runs once when you press reset or power the board:
void setup() { // Start setup:
  // We start the serial library to output our messages:
  if (DEBUG) {
  } // End if (DEBUG):
  while (!Serial) {
    ; // Wait for serial port to connect. Needed for native USB port only:
  } // End while(!Serial):
  Serial.println(F("\nDHT TEST PROGRAM"));
  Serial.print(F("\nLIBRARY VERSION: "));
  Serial.println(DHT11LIB_VERSION);
  Serial.print(F("\nConnected PIN: "));
  Serial.println(DHT11_PIN);
  Serial.println(F("\nType,\tStatus,\tRH (%),\tT (C)"));
  delay(1000); // Delay to let system boot:
} // End setup:
// The loop function runs over and over again forever:
void loop() { // Start loop:
  Serial.print("DHT11, \t");
  int chk = DHT.read(DHT11_PIN); // Read the value returned from sensor at digital PIN:
  switch (chk) {
    case DHTLIB_OK: // The sensor samples and its checksum are OK:
      Serial.print(F("OK,\t"));
    case DHTLIB_ERROR_CHECKSUM: // The checksum test failed:
      Serial.print(F("Checksum error,\t"));
    case DHTLIB_ERROR_TIMEOUT: // A timeout occurred, and communication has failed:
      Serial.println(F("Time out error,\t"));
      delay(1000); // Wait 1 minutes before accessing sensor again:
      return;
    default:
      Serial.print(F("Unknown error,\t"));
  } // End switch (chk):
  Serial.print(DHT.humidity, 1); // Print the humidity:
  Serial.print(F(",\t"));
  Serial.println(DHT.temperature, 1); // Print the temperature:
} // End loop:
Grazie in anticipo.
Se all'inizio funzionava e adesso no, escludo possa essere un problema di codice. I DHT11 sono sensori mediocri, per non dire di peggio e infatti costano molto poco. O magari qualcosa fa falso contatto, controlla bene i fili, oppure il sensore è partito. In che condizioni veniva usato il sensore e da quanto tempo? Comunque il tuo sensore non ha bisogno della Rpullup perché già la ha sul modulo del pcb mi sembra.
As_Needed:
L'ho comprato a maggio e l'ho sempre usato in casa.
Ne comprerò un altro di modello diverso.
Grazie
Tieni presenti che già il DHT22 se dura un anno è un buon risultato, il DHT11 dura ancora meno :slight_smile: Evita particolari gas sul sensore, vapori pure
