avete ragione, ma nella fretta mi ero dimenticato di specificare anche la variabile. Premetto che lo sketch non è mio. Ora vi posto il codice completo in modo da fare prima.
// include the library code:
#include <EEPROM.h>
#include <LiquidCrystal.h>
#include <Time.h>
#include <Tone.h>
#include <Wire.h>
// DS13O7 support
#include <DS1307RTC.h>
#include <Wire.h>
// external EEPROM define type 24C64 address 0
#define DEV_ADDR 0x50
void i2c_eeprom_write_byte( int deviceaddress, unsigned int eeaddress, byte data ) {
int rdata = data;
Wire.beginTransmission(deviceaddress);
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.write(rdata);
Wire.endTransmission();
byte i2c_eeprom_read_byte( int deviceaddress, unsigned int eeaddress ) {
byte rdata = 0xFF;
Wire.requestFrom(deviceaddress,1);
if (Wire.available()) {
rdata = Wire.read();
return rdata;
byte vp =32; // test counter char for external eprom
// declare the tones as an array
Tone sound;
const int DTMF[] = { 2200, 3300, 4600, 3800, 3800, 3800, 3800, 10000, 10000, 2200, 2200, 2200, 2200, 2200, 2200, 10000, 10000, 10000, 3800, 3800};
byte si=0; //variable increment counter note sound
// Tone output pin
const byte TONE_PIN = A1;
// default parameters array
// HH MM Pat Med HH MM Pat Med HH MM Pat Med HH MM Pat Med
const byte def_par[] = { 8, 0, 1, 1, 8, 30, 1, 2, 9, 0, 1, 3, 9, 30, 1, 4,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
//declaration variables
int analogpin = 0; //variable input analog buttons
byte keycount = 0; //counter effective push button
byte keyDW = 0; //button key Down
byte keyUP = 0; //button key Up
byte keyACK = 0; // button key aquisition alarm
byte keyESC = 0; // button key exit function
byte keyCFG = 0; // button key configuration system
byte push = 0; // variable status botton
byte mempush = 0; // variable memory botton pressed
int prg = 0; // variable status program configuration
byte memalarm = 0; // variable status alarm
int s_old = 0; // memory old minute alarm
byte alarm = 0; // alarm active
int sel = 0; // select view alarms
byte lamp = 0; // blink on/off
byte sold = 0; // memory second old
int tast = 0; // value increase / decrease parameter
int ho_old=0; // mem old hour set
int mi_old=0; // mem old minute set
int da_old=0; // mem old day set
int mo_old=0; // mem old month set
int ye_old=0; // mem old year set
byte alm_h[33]; // array variable alarm hour view
byte alm_m[33]; // array variable alarm minute view
byte med[33]; // array variable alarm medicinale view
byte pat[33]; // array variable alarm patient
byte medic[1]; // variable view led alarm auxiliary
byte mtast; // memory pressure key up or down
byte mmin=0; // memory counter for auto-clear segnalation alarm
byte min_old=0; // counter minute for auto-clear segnalation delay
byte adjs=48; // adj off-set second time for day when not use the RTC
byte ltime=1; // legal time
byte memltime=0; // memory change legal time
byte _lang=0; // memory select language // tuxduino: underscore prefix means don't access this variable directly; use getCurrLang(), setCurrLang() instead
//int ramLibera = freeRam(); // define freeRam(); function for view sram free //R.0.5d
// Localization management by tuxduino
// list of defined languages
enum {
LANG_FIRST = 0,
LANG_EN = 0,
LANG_IT = 1,
LANG_LAST = 1,
// eeprom memory address of language setting by tuxduino
const byte EE_LANG_ADDR = 128;
// number of defined languages by tuxduino
const byte NUM_LANGS = LANG_LAST + 1;
// max size of localized string (including null-terminator)
// const byte MAX_STR_LEN = 17
// localized strings by tuxduino
const char* strings[][NUM_LANGS] = {
// 0123456789012345 0123456789012345
"SetDefault_ALARM", "Allarmi_predef. ", // 0
"Patient_" , "Paziente" , // 1
"Medicine______" , "Medicina______" , // 2
"____NO_ALARM____", "_NESSUN_ALLARME_", // 3
"SET_hours_______", "Impostazione_ore", // 4
"SET_minutes_____", "Impostaz._minuti", // 5
"SET_day_________", "Impostaz._giorno", // 6
"SET_month_______", "Impostaz.___mese", // 7
"SET_year________", "Impostaz.___anno", // 8
"SET_ADJ_sec_time", "Regol.sec.giorno", // 9
"SET_Day.Sav.Time", "Attiv.ora_legale", // 10
"SET_Lang.__EN/IT", "Linguaggio_EN/IT", // 11
"SET_Sound.Pat._1", "Suoneria_Paz.__1", // 12
"SET_Sound.Pat._2", "Suoneria_Paz.__2", // 13
" Time:" , " Ore:" , // 14
"Pat.:" , "Paz.:" , // 15
"SET_hour____AL" , "SET_ore_____AL" , // 16
"SET_min.____AL" , "SET_minuti__AL" , // 17
"SET_Patient_AL" , "SET_Pazient_AL" , // 18
"SET_Medicin_AL" , "SET_Medicin_AL" , // 19
// localized strings identifiers by tuxduino
enum {
STR_SET_DEFAULT_ALARM = 0,
STR_PATIENT = 1,
STR_MEDICINE = 2,
STR_NO_ALARM = 3,
STR_SET_HOURS = 4,
STR_SET_MINUTES = 5,
STR_SET_DAY = 6,
STR_SET_MONTH = 7,
STR_SET_YEAR = 8,
STR_ADJ_SEC = 9,
STR_SET_LEGAL_TIME = 10,
STR_SET_LANG = 11,
STR_SET_SOUND_PAT_1 = 12,
STR_SET_SOUND_PAT_2 = 13,
STR_TIME = 14,
STR_PAT = 15,
STR_SET_HOUR_AL = 16,
STR_SET_MIN_AL = 17,
STR_SET_PATIENT_AL = 18,
STR_SET_MEDICINE_AL = 19
// the the localized version of the specified string by tuxduino
const char* getString(byte stringId) {
return strings[stringId][_lang];
// select language; the selection is stored in eeprom by tuxduino
void setCurrLang(byte langId) {
if (langId < NUM_LANGS) {
_lang = langId;
EEPROM.write(EE_LANG_ADDR, _lang);
// get current language selection by tuxduino
byte getCurrLang() {
return _lang;
// read the currently selected language from eeprom by tuxduino
// initialize eeprom setting if necessary
void initLangFromEeprom() {
byte lang;
lang = EEPROM.read(EE_LANG_ADDR); // read language setting from eeprom
if (lang > LANG_LAST) { // if the value is invalid
lang = LANG_FIRST; // set it to a default value
EEPROM.write(EE_LANG_ADDR, lang); // and save it
// update global variable by tuxduino
_lang = lang;
// declare variable matrix by tuxduino R05G
const byte NUM_ROWS = 4;
const byte NUM_COLS = 4;
byte rowPins[NUM_ROWS] = { 2, 3, 4, 5 };
byte colPins[NUM_ROWS] = { 6, 7, 8, 9 };
byte cnt = 0;
byte value = 1;
byte sel_sound1=0; // memory select sound patient 1
byte sel_sound2=0; // memory select sound patient 2
// initialize the library with the numbers of the interface pins //ATTENZIONE, PIN DISPLAY. MA CON I2C?
LiquidCrystal lcd(A2, A3, 10, 11, 12, 13);
// bug Rev.0.5g1
// lang=EEPROM.read(0); // read language by eprom
// if (lang>1) {lang=0;EEPROM.write(0,0);}//set to standard language "GB" if no setting
initLangFromEeprom(); // by tuxduino
sel_sound1=EEPROM.read(129); // read sound patient 1
if (sel_sound1>9) {sel_sound1=0;EEPROM.write(129,0);}//set to standard sound patient 1
sel_sound2=EEPROM.read(130); // read sound patient 2
if (sel_sound2>9) {sel_sound2=0;EEPROM.write(130,0);}//set to standard sound patient 2
Serial.begin(9600); // start serial monitor //R.0.5d
Wire.begin();
sound.begin(TONE_PIN);
sound.play(DTMF[3], 500);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message version project to the LCD on start-up.
lcd.print("ArduoMemoryR1.0c");
lcd.setCursor(0, 1);
lcd.print("By Giuseppe & Co");
//analogButtons.checkButtons();
delay (1000);
// verify push down at start up for default parameter set
// if (digitalRead(keyDW)== 1) { // key down start up active
if (analogRead(analogpin)>=676 && analogRead(analogpin)<=678) { // key down start up active
lcd.print(getString(STR_SET_DEFAULT_ALARM)); //R.0.5f
sound.play(DTMF[4], 500);
for (int i=0; i <= 31; i++){
alm_h[i+1]=def_par[(i*4)];
EEPROM.write((i*4), def_par[(i*4)]);
alm_m[i+1]=def_par[(i*4)+1];
EEPROM.write((i*4)+1, def_par[(i*4)+1]);
pat[i+1]=def_par[(i*4)+2];
EEPROM.write((i*4)+2,def_par[(i*4)+2]);
med[i+1]=def_par[(i*4)+3];
EEPROM.write((i*4)+3, def_par[(i*4)+3]);
alm_h[i+1]=EEPROM.read(i*4);
alm_m[i+1]=EEPROM.read((i*4)+1);
pat[i+1]=EEPROM.read((i*4)+2);
med[i+1]=EEPROM.read((i*4)+3);
delay (1000);
//set start Time(hr,min,sec,day,month,yr);
//setTime(12,00,00,21,11,2012);
// set RTC DS1307 as current time source R.1.0.0
setSyncProvider(RTC.get);
//test leds and buzzer for 2 second
sound.play(DTMF[1], 500);
allOn(1);//all led on patient 1
lcd.print("Patient_TEST__01");
delay (1000);
//lcd.setCursor(0, 0);
lcd.print("Patient_TEST__02");
allOff();
allOn(0);//all led on patient 2
delay (1000);
//lcd.setCursor(0, 0); //R.0.5d
allOff();
lcd.clear();
}// end setup
// adj real time correction(increase adjs second for day"
if (hour() == 23 && minute() == 59 && second() == 60-adjs){
setTime(23,59,59,day(),month(),year());
// also update RTC
RTC.set(now());
// automatic legal time correction +1
if (ltime==1 && hour() == 2 && minute() == 00 && second() == 00 && weekday() == 1 && month()== 3 && day() > 24 ){
setTime(03,00,00,day(),month(),year());
memltime=0;
// also update RTC
RTC.set(now());
// automatic legal time correction -1
if (memltime == 0 && ltime==1 && hour() == 3 && minute() == 00 && second() == 00 && weekday() == 1 && month()== 10 && day() > 24 ){
setTime(02,00,00,day(),month(),year());
memltime=1;
// also update RTC
RTC.set(now());
// verify if is active all's alarms (1-32)
// PS.: The first section n. 0 is used for view segnalation alarm when active
for (int i=1; i <= 32; i++){
if (alm_h[i] == hour() && alm_m[i] == minute() && med[i] != 0 && prg==0 && memalarm == 0 ){
alarm = 1;
alm_h[0] = alm_h[i];
alm_m[0] = alm_m[i];
pat[0] = pat[i];
med[0] = med[i];
} // end for i active alarms
//read status button acknoleg
push = 0; //reset memory push pressed
//// assign the push button read select
inputbuttons();
if (keyCFG== HIGH) {push = 5; }// key cgf system select
if (keyESC== HIGH) {push = 4; }// key esc select
if (keyDW== HIGH) {push = 3; }// key down select
if (keyUP== HIGH) {push = 2; }// key up select
if (keyACK== HIGH) {push = 1; }// key ENTER/ACK select
if (push == 2) {
byte b = i2c_eeprom_read_byte(DEV_ADDR, 0);
Serial.println(b);
Serial.println(vp);
if (push == 3) {
vp=vp+1;
i2c_eeprom_write_byte(DEV_ADDR, 0 , vp);
if (keyDW== 0 && keyUP== 0 && keyACK== 0 && keyESC== 0 && keyCFG== 0) {mempush = 0; }// reset memory push button & exe function
if (push == 1 && alarm == 1 && mempush == 0) {// acknoleg alarm
mempush=1;
memalarm = 2;
alarm = 0;
rexit();
medic[0] = med[0];
verirow();
// reset memory alarm old
if (push == 1 && alarm == 0 && memalarm == 1 && mempush==0) {
mempush = 1;
gen_reset();
// verify new minute in alarm for automatically noise off
if (second() == s_old && memalarm == 1) {
alarm = 0;
// reset total alarm and memory after minute
if (second() == s_old && memalarm == 2) {
gen_reset();
// set start minute memory alarm and view single medicine
if (alarm == 1 && memalarm == 0) {
memalarm = 1;
s_old = 59;
min_old = minute();
mmin = 0;
}// end if set start minute memory alarm
// increase minute counter memory of alarm segnalation
if (memalarm == 1 && min_old != minute()) {
mmin++;
min_old = minute();
// reset auto-clear memory alarm segnalation after 30 minutes
if (memalarm == 1 && mmin == 30) {
gen_reset();
// generation blink second
if (sold != second()) {
sold = second();
lamp = not lamp;
// active alarm noise segnalation
if (lamp == 1 && alarm == 1 && memalarm != 2) {
noise_alarm();//call noise alarm segnalation
si=0;
//write the time & date o LCD
if (prg == 0){
printDigits(hour());// hour current time
if (lamp == 1) {lcd.print("*");
lcd.print(":");
} //segnalation run second
printDigits(minute());//minute current time
//view date & patient blinking if alarm is run
if (lamp == 1 && memalarm == 1) {
//reset all led
allOff();
printDigits(alm_h[0]);
lcd.print(".");
printDigits(alm_m[0]);
lcd.setCursor(6, 0);
lcd.print(getString(STR_PATIENT));
lcd.setCursor(14, 0);
printDigits(pat[0]);
lcd.print(getString(STR_MEDICINE));
lcd.setCursor(14, 1);
printDigits(med[0]);
medic[0] = med[0];
verirow();
//view current date
lcd.print("_");
printDigits(day());
lcd.print("/");
printDigits(month());
lcd.print("/");
printDigits(year());
if (prg == 0 && memalarm == 0){
lcd.print(getString(STR_NO_ALARM));
} //end write the time & date in standby mode
configuration(); // call configuration subroutine
// Serial.println(ramLibera); //view memory free
//Serial.println(weekday()); //view week day for test legal time
}//end loop program
//function for check free sram //R.0.5d
//int freeRam () {
// extern int __heap_start, *__brkval;
// int v;
// return (int) &v - (__brkval == 0 ? (int) &__heap_start : (int) __brkval);
void noise_alarm(){
//generation noise alarm for patient
if (pat[0]==1) {
si=si+sel_sound1;
if (si > 20) {si=1;}
sound.play(DTMF[si], 50+(sel_sound1*200));
if (pat[0]==2) {
si=si+sel_sound2;
sound.play(DTMF[si], 50+(sel_sound2*200));
void configuration(){
// configuration system program parameters
if (prg == 81) {
lcd.print(getString(STR_SET_HOURS));// by tuxduino
ho_old = ho_old + tast;
if (ho_old > 23 || ho_old < 0) {ho_old = 0;}
tast = 0;
printDigits(ho_old);
if (prg == 82) {
lcd.print(getString(STR_SET_MINUTES));// by tuxduino
mi_old = mi_old + tast;
if (mi_old > 59 || mi_old < 0) {mi_old = 0;}
tast = 0;
printDigits(mi_old);
if (prg == 83) {
lcd.print(getString(STR_SET_DAY));// by tuxduino
da_old = da_old + tast;
if (da_old > 31 || da_old < 1) {da_old = 1;}
tast = 0;
printDigits(da_old);
if (prg == 84) {
lcd.print(getString(STR_SET_MONTH));// by tuxduino
mo_old = mo_old + tast;
if (mo_old > 12 || mo_old < 1) {mo_old = 1;}
tast = 0;
printDigits(mo_old);
if (prg == 85) {
lcd.print(getString(STR_SET_YEAR));// by tuxduino
ye_old = ye_old + tast;
if (ye_old > 2030 || ye_old < 1970) {ye_old = 2012;}
tast = 0;
printDigits(ye_old);
if (prg == 86) {
lcd.print(getString(STR_ADJ_SEC));// by tuxduino
adjs = adjs + tast;
if (adjs > 59 || adjs < 0) {adjs = 0;}
tast = 0;
printDigits(adjs);
if (prg == 87) {
lcd.print(getString(STR_SET_LEGAL_TIME));// by tuxduino
ltime = ltime + tast;
if (ltime > 1 || ltime < 0) {ltime = 0;}
tast = 0;
printDigits(ltime);
memltime=0;
if (prg == 88) {
byte lang;
lcd.print(getString(STR_SET_LANG));// by tuxduino
lang = getCurrLang() + tast;
lang = LANG_FIRST;
setCurrLang(lang);
tast = 0;
printDigits(lang);
memltime=0;
if (prg == 89) {
lcd.print(getString(STR_SET_SOUND_PAT_1));// by tuxduino
sel_sound1 = sel_sound1 + tast;
//check the sound patient n.1 selected
if (sel_sound1 > 9 || sel_sound1 < 0) {sel_sound1 = 0;}
EEPROM.write(129,sel_sound1);
tast = 0;
printDigits(sel_sound1);
memltime=0;
if (prg == 90) {
lcd.print(getString(STR_SET_SOUND_PAT_2));// by tuxduino
//check the sound patient n.2 selected
sel_sound2 = sel_sound2 + tast;
if (sel_sound2 > 9 || sel_sound2 < 0) {sel_sound2 = 0;}
EEPROM.write(130,sel_sound2);
tast = 0;
printDigits(sel_sound2);
memltime=0;
//check the end of configuration system
if (prg == 91) {
lcd.clear();
prg = 0;
sel = 0;
alarm = 0;
memalarm = 0;
tast=0;
mtast=0;
setTime(ho_old,mi_old,0,da_old,mo_old,ye_old); //set new time&date
// also update RTC
RTC.set(now());
// configuration parameters of alarms
//increase or decrease hour alarm select
if (prg == 1) {
alm_h[sel+1] = alm_h[sel+1] + tast;
if (alm_h[sel+1] > 23 || alm_h[sel+1] < 0) {alm_h[sel+1] = 0;}
checkhour(alm_h[sel+1]);
//write to eprom the parameter change
EEPROM.write((sel*4)+prg-1, alm_h[sel+1]);
//increase or decrease minute alarm select
if (prg == 2) {
alm_m[sel+1] = alm_m[sel+1] + tast;
if (alm_m[sel+1] > 59 || alm_m[sel+1] < 0) {alm_m[sel+1] = 0;}
checkmin(alm_m[sel+1]);
EEPROM.write((sel*4)+prg-1, alm_m[sel+1]);
//increase or decrease patient alarm select
if (prg == 3) {
pat[sel+1] = pat[sel+1] + tast;
if (pat[sel+1]> 2 || pat[sel+1] < 1) {pat[sel+1] = 1;}
checkpat(pat[sel+1]);
EEPROM.write((sel*4)+prg-1, pat[sel+1]);
//increase or decrease medicine alarm select
if (prg == 4) {
med[sel+1] = med[sel+1] + tast;
if (tast != 0) {mtast=1;}// memory pressure key up or down
//verify patient select for to assigne the medicine
if ((med[sel+1]> 16 || med[sel+1] < 0) && pat[sel+1] == 1) {med[sel+1] = 0;}
// if ((med[sel+1]> 32 || med[sel+1] < 17) && pat[sel+1] == 2) {med[sel+1] = 17;} //bug R05h 24-11-2012
if (med[sel+1]==1 && pat[sel+1] == 2) {med[sel+1] = 17;} //bug R05h 24-11-2012
if ((med[sel+1]> 32 || med[sel+1] < 0 || med[sel+1] ==16) && pat[sel+1] == 2) {med[sel+1] = 0;} //bug R05h 24-11-2012
checkmed(med[sel+1]);
EEPROM.write((sel*4)+prg-1, med[sel+1]);
//parameter view on displey
med[0]=med[sel+1];
pat[0]=pat[sel+1];
verirow();
if (mtast == 1) {// verify pressure key up or down
mtast=0;// reset memory pressure key up or down
verirow();
if (prg == 5) {//exit prog time and date
gen_reset();//general reset
// acknoleg alarms and confirm configurations parameters
if (push == 1 && mempush == 0) {// verify preseed enter button (ACK)
if (mempush ==0 && prg >= 1 && prg < 5 ) {// enter select change parameter of alarm
mempush=1;
prg = prg + 1;
lcd.clear();
rexit();//reset and exit program parameter
if (mempush ==0 && prg == 81) {// confirm hour time
mempush=1;
prg = prg + 1;
lcd.clear();
mi_old = minute();//set minute memory for autoexit after 1 minute
rexit();
if (mempush ==0 && prg == 82) {// confirm minute time
mempush=1;
prg = prg + 1;
lcd.clear();
da_old = day();
rexit();
if (mempush ==0 && prg == 83) {// confirm day date
mempush=1;
prg = prg + 1;
lcd.clear();
mo_old = month();
rexit();
if (mempush ==0 && prg == 84) {// confirm month date
mempush=1;
prg = prg + 1;
lcd.clear();
ye_old = year();
rexit();
if (mempush ==0 && (prg >= 85 && prg <= 90) ) {// confirm year date, adjs, legal time
mempush=1;
prg = prg + 1;
lcd.clear();
rexit();
if (prg == -1) {// editor select alarm for change
mempush=1; //bug Rev.0.5a
prg = 1;
lcd.clear();
rexit();
}// end acknoleg alarms
//test pressure key
//// if (push == 1) {Serial.println("ent");}
//// if (push == 2) {Serial.println("up");}
//// if (push == 3) {Serial.println("down");}
// decrease the parameter select
if (push == 3 && prg >= 1 && mempush == 0) { //decrease data
mempush = 1;
tast=-1;
rexit();
// increase the parameter select
if (push == 2 && prg >= 1 && mempush == 0) { //increase data
mempush = 1;
tast=1;
rexit();
// verify the push pressed for open configuration system
if (push == 5 && prg == 0 && mempush == 0 && (memalarm == 0 || memalarm ==2)) { //open configuration system
mempush = 1;
memalarm=0;
alarm=0;
prg = 81;
ho_old = hour(); //memory old hour before change
lcd.clear();
sel = 0;
rexit();
//push=0;
// verify the push pressed for open configuration alarms
if (push == 3 && prg == 0 && mempush == 0 && (memalarm == 0 || memalarm ==2)) { //open configuration parameters alarms
mempush = 1;
memalarm=0;
alarm=0;
prg = -1;
sel = 0;
rexit();
if (push == 2 && prg == 0 && mempush == 0 && (memalarm == 0 || memalarm ==2)) { //open configuration parameters alarms
mempush = 1;
memalarm=0;
alarm=0;
prg = -1;
sel = 31;
rexit();
// increase the alarm view
if (push == 3 && prg == -1 && mempush == 0) { //increase view
mempush = 1;
memalarm=0;
alarm=0;
sel = sel + 1;
rexit();
if (sel > 31) {sel = 31;}
// decrease the alarm view
if (push == 2 && prg == -1 && mempush == 0) { //decrease view
mempush = 1;
sel = sel - 1;
rexit();
if (sel < 0) {sel = 0;}
// verify the time for insert the new parameter
if ((s_old == second() || push==4) && prg != 0){//reset automatically function if don't touch buttons
lcd.clear();
prg = 0;
sel = 0;
alarm = 0;
memalarm = 0;
med[0]=0;
tast=0;
mtast=0;
//verirow();
allOff();
s_old=second();
rexit();
//view the parameters set of alarms
if (prg == -1){
lcd.print("AL");
lcd.print(sel+1);
lcd.print(getString(STR_TIME));
printDigits(alm_h[sel+1]);
lcd.print(".");
printDigits(alm_m[sel+1]);
lcd.print(" ");
lcd.print(getString(STR_PAT));
printDigits(pat[sel+1]);
lcd.print("__Med.:");
printDigits(med[sel+1]);
void gen_reset(){// general reset clear view all memory segnalation
prg=0;
sel=0;
memalarm = 0;
medic[0]=0;
med[0]=0;
alm_h[0]=0;
alm_m[0]=0;
pat[0]=0;
tast=0;
mtast=0;
lcd.clear();
// reset all led and all line led
allOff();
void rexit(){ //reset timer 1 minute for auto exit program
s_old = second()-1;
if (s_old < 0) {s_old = 59;}
sound.play(DTMF[5], 50);
void printDigits(int digits){ // utility function for digital clock display: prints preceding colon and leading 0
if(digits < 10)
lcd.print('0');
lcd.print(digits);
}// end void printDigit
void checkhour(int digh){// utility for print description set hour of alarm
lcd.print(getString(STR_SET_HOUR_AL));// by tuxduino
lcd.print(sel+1);
lcd.print(" ");
tast = 0;
printDigits(digh);
void checkmin(int digm){// utility for print description set minute of alarm
lcd.print(getString(STR_SET_MIN_AL));// by tuxduino
lcd.print(sel+1);
lcd.print(" ");
tast = 0;
printDigits(digm);
void checkpat(int digp){// utility for print description set patient of alarm
lcd.print(getString(STR_SET_PATIENT_AL));// by tuxduino
lcd.print(sel+ 1);
lcd.print(" ");
tast = 0;
printDigits(digp);
void checkmed(int dige){// utility for print description set medicine of alarm
lcd.print(getString(STR_SET_MEDICINE_AL));// by tuxduino
lcd.print(sel + 1);
lcd.print(" ");
tast = 0;
printDigits(dige);
// function set all led to OFF by tuxduino
void allOff() {
byte i;
for (i = 0; i < NUM_COLS; i++) {
pinMode(colPins[i], INPUT);
for (i = 0; i < NUM_ROWS; i++) {
pinMode(rowPins[i], INPUT);
// function set all led to ON by tuxduino
void allOn(byte highOrLow) {
byte i;
pinMode(colPins[i], OUTPUT);
digitalWrite(colPins[i], highOrLow);
pinMode(rowPins[i], OUTPUT);
digitalWrite(rowPins[i], !highOrLow);
void verirow() {
// select patient 1 or 2 and adj number of medicine (modified for insert writeCell on release R05G1)
if(med[0] >16){cnt=med[0]-17; value=0;} else {cnt=med[0]-1; value=1;}
writeCell(cnt,value);
// function by tuxduino, insert by Giuseppe G. in the software release R.05G
// cellNumber: 0..ROW*COLS
// value: HIGH=1=patient2 or LOW=0=patient1
void writeCell(byte cellNum, byte value) {
byte row;
byte col;
row = cellNum / NUM_COLS;
col = cellNum % NUM_COLS;
allOff();
pinMode(colPins[col], OUTPUT);
digitalWrite(colPins[col], value);
pinMode(rowPins[row], OUTPUT);
digitalWrite(rowPins[row], !value);
//function select button pressed insert on R_1_0_0a
void inputbuttons()
int ib=0;
ib = analogRead(analogpin);
if (keycount == 5 && ib>=676 && ib <=678) {keyDW=1; } else {keyDW=0; }// key down
if (keycount == 5 &&ib>=438 && ib <=440) {keyUP=1; } else {keyUP=0; }// key up
if (keycount == 5 &&ib>=240 && ib <=242) {keyACK=1; } else {keyACK=0; }// key ack / Enter
if (keycount == 5 &&ib>=193 && ib <=195) {keyESC=1; } else {keyESC=0; }// key Esc
if (keycount == 5 &&ib>=119 && ib <=121) {keyCFG=1; } else {keyCFG=0; }// key CFG system
if (keycount > 30 ) {keycount=0; } // repeat time key pressed
if (ib < 1000) {keycount++; } else {keycount=0; }// key press = 0
//end sketch ArduinoMemory Reminder By Giuseppe G. (FABLAB Torino)
