je bloque sur la lib liquidcristal lorsque j essai de compilé l exemple 'hello word ' j ai une erreur de compilation
j ai beau essayer de dsinstallé et reinstallé meme chose et j ai meme retelechargé la lib et tjr le meme pb qui persiste
In file included from HelloWorld.pde:39:
C:\Users\Valdano\Documents\Arduino\libraries\LiquidCrystal/LiquidCrystal.h:86: error: conflicting return type specified for 'virtual void LiquidCrystal::write(uint8_t)'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\arduino/Print.h:48: error: overriding 'virtual size_t Print::write(uint8_t)'
rebonjour les amis
voilà le code c un exemple fournis avec la lib LiquidCrystal Library quand je compile j ai la même erreur
code erreur
et voilà le code de l exemple
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
* LCD RS pin to digital pin 12
* LCD Enable pin to digital pin 11
* LCD D4 pin to digital pin 5
* LCD D5 pin to digital pin 4
* LCD D6 pin to digital pin 3
* LCD D7 pin to digital pin 2
* LCD R/W pin to ground
* 10K resistor:
* ends to +5V and ground
* wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/LiquidCrystal
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis()/1000);
Essaie de mettre à jour ta version de l'IDE Arduino: vu qu'apparemment tes fichiers sont des .pde, ça me laisse penser que tu as peut-être une vieille version de l'IDE qui n'est pas compatible avec la librairie.
Bonsoir les amis
voilà le pb est réglé mtn sauf que mon lcd n affiche rien la lib est faite pour un lcd 162 moi j en est un de 204 et en plus il a 20 pins et e mode // , es que ya une lib spécial pour ce genre de lcd ?
j ai essayer la config avec lcd.begin(20,4) mais ca ne marche pas puisk mon lcd a 20 pins
ya til un exemple pour que je puisse le suivre
Merci
valdano:
Avec une référence du lcd en question ce serait bien plus simple de répondre
