Hi, I purchased two Bluetooth HC-05 modules to use with Arduino. when I go into slave mode they give me both the name and the password. But if I want to change the password it returns me an Error(ID1).
Once the application has been created with mittappinventor, the app does not find any Bluetooth in the list (which is not inherent to the hc-05).ù
Can you match my Android 13 version? if I can't connect with the phone I can't do any tests regarding the HC-05.
One last thing, if I try to connect to Bluetooth it pairs but doesn't pair. Can you give me a hand?
1. Check that the HC-05 is function by operating it with Arduino UNO and BT Terminal of your Android Phone.
2. Change parameters of BT from UNO using AT Commands.
both modules give the same problems. In AT mode with arduino I can read the name, I can change it, I can read the PSWD but I can't change it. the modules were purchased separately from two different sellers.
instead with the phone it tells me that it is paired but the module always flashes quickly
Install a BT Terminal from Playstore and check that you can exchnage data between Serial Moniotr of UNO and the BT Terminal of your Phone.
