Problems calculating the position of the sun
I have a error with the librery SunPosition, this is my code
#include <SunPosition.h>
#include <UnixTime.h>
float latitude = 37.7749;
float longitude = -122.4194;
int timeZone = -8;
unsigned long lastUpdateTime = 0;
  unsigned long currentTime = millis();
  if (currentTime - lastUpdateTime >= 10000) {
    lastUpdateTime = currentTime;
    SunPosition sunPosition;
    sunPosition.compute(latitude, longitude, 0, timeZone);
    float solarAngle = static_cast<float>(sunPosition.angle180());
    Serial.print("Ángulo solar: ");
    Serial.print(solarAngle);
    Serial.println(" grados");
What is the error?
Where did you find that library?
How does that library know the time of day?
This library works extremely well, and I recommend it: GitHub - KenWillmott/SolarPosition: Arduino Library to calculate the position of the sun relative to geographic coordinates
You do need to give it the correct time of day.
I would think that the position of any celestial body is expressed as two coordinates
This might be written for "terrestrial" observers, with lat/lon is right-ascension and angle is declination to avoid introducing new terms too soon.
HI, @alfredo133
Welcome to the forum.
What model Arduino are you using?
Does it compile?
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
