Hi Guys,
Im pretty new to the Arduino and am encountering some sticking points that I dont really understand how to get past.
I am trying to get a basic temperature reading from the digital waterproof sensor I have but whenever I upload the code the serial monitor gives back the number 85.00 over and over again. My eventual goal is to be notified when a specific temperature has been reached, 60C to be exact.
I have uploaded the code, pictures of my circuit (edit - in the pictures it is shown on pin 5, we have now moved it to pin 10 so this is not a unknown mistake) and of the serial monitor below. Thanks for your help.
new code
#include <OneWire.h>
// DS18S20 Temperature chip i/o
OneWire ds(10); // on pin 10
void setup(void) {
// initialize inputs/outputs
// start serial port
void loop(void) {
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
byte i;
byte present = 0;
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
Serial.print("No more addresses.\n");
ds.reset_search();
return;
Serial.print("R=");
for( i = 0; i < 8; i++) {
Serial.print(addr[i], HEX);
Serial.print(" ");
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
if ( addr[0] == 0x10) {
Serial.print("Device is a DS18S20 family device.\n");
else if ( addr[0] == 0x28) {
Serial.print("Device is a DS18B20 family device.\n");
else {
Serial.print("Device family is not recognized: 0x");
Serial.println(addr[0],HEX);
return;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
delay(1000); // maybe 750ms is enough, maybe not
// we might do a ds.depower() here, but the reset will take care of it.
present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
Serial.print("P=");
Serial.print(present,HEX);
Serial.print(" ");
for ( i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
Serial.print(data[i], HEX);
Serial.print(" ");
Serial.print(" CRC=");
Serial.print( OneWire::crc8( data, 8), HEX);
LowByte = data[0];
HighByte = data[1];
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2's comp
Tc_100 = (6 * TReading) + TReading / 4; // multiply by (100 * 0.0625) or 6.25
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print("0");
Serial.print(Fract);
Serial.print("\n");
