Hello,
Im new to this site and I hope I put this problem on the correct forum topic.
I'm currently building this project
http://www.instructables.com/id/Arduino ... /?ALLSTEPS
Everything is setup and working properly,
but I would like to add something else which I'm having issues with.
I would like to add a Ultrasonic sensor into that project.
http://letsmakerobots.com/files/field_p ... R04-lg.jpg
I really suck at programming, I mean, I really SUCK. Hoping someone could do this for me or show me the right direction on how to accomplish this.
Basically, I just want the different lights to light up when an object is either far or close to the sensor.
Here's my code so far(everything works except for the ultrasonic):
//pins ultrasonic
int triggerPort = A4;
int echoPort = A5;
const int RED = 9; // define digital output pins for individual red,
const int GREEN = 10; //green and blue channels
const int BLUE = 11;
int colorRed;
int colorGreen;
int colorBlue;
const int POT1 = A0; // define analog input pins for three potentiometers
const int POT2 = A1;
const int POT3 = A2;
const int POT4 = A3;
const int BUTTON = 2; // define digital input pin for the switch
int val = 0; // stores the state of the switch input pin
int FADESPEED = 0; // initiate fade speed set by potentiometer
int r = 0; // initialize the red, green and blue values
int g = 0;
int b = 0;
void setup(){
pinMode(RED, OUTPUT); // define digital pins as outputs and inputs as needed
pinMode(GREEN, OUTPUT);
pinMode(BLUE, OUTPUT);
pinMode(BUTTON, INPUT);
pinMode(triggerPort, OUTPUT);
pinMode(echoPort, INPUT);
void loop(){
digitalWrite(triggerPort, LOW);
digitalWrite(triggerPort, HIGH);
delayMicroseconds(10);
digitalWrite( triggerPort, LOW);
long time = pulseIn(echoPort, HIGH);
long range = 0.034 * time / 2;
colorRed = (range20) % 255;
colorBlue = (range30) % 255;
colorGreen = (range*50) % 255;
analogWrite(RED, colorRed);
analogWrite(BLUE, colorBlue);
analogWrite(GREEN, colorGreen); delay( 400 );
val = digitalRead(BUTTON); // read the input value from the toggle switch
if (val == HIGH){
// code for RGB color fade
FADESPEED = analogRead(POT4)/10; // set the fade speed by reading analog input from 4th potentiometer
// analogRead will output a number between 0 and 1023, and "delay"
// is in milliseconds, so the biggest delay you'll get here is about
// 1/10 of a second. Divide by a different number to change the max
// fade time.
// fade from blue to violet
for (r = 0; r < 256; r++) {
analogWrite(RED, r);
FADESPEED = analogRead(POT4)/10; // check the fade speed continuously, otherwise
// it won't update until it's gone through a complete cycle.
// Probably not the most efficient way to do this...
delay(FADESPEED);
// fade from violet to red
for (b = 255; b > 0; b--) {
analogWrite(BLUE, b);
delay(FADESPEED);
// fade from red to yellow
for (g = 0; g < 256; g++) {
analogWrite(GREEN, g);
delay(FADESPEED);
// fade from yellow to green
for (r = 255; r > 0; r--) {
delay(FADESPEED);
// fade from green to teal
for (b = 0; b < 256; b++) {
delay(FADESPEED);
// fade from teal to blue
for (g = 255; g > 0; g--) {
delay(FADESPEED);
else {
// code for individual RGB control with potentiometers
r = analogRead(POT3)/4; // read values from the 3 potentiometers and divide by 4 to set brightness
g = analogRead(POT2)/4; // note that analog read is 10-bit (0-1023), analog write is an 8-bit PWM
b = analogRead(POT1)/4; // signal so you need to divide this value by 4.
analogWrite(RED, r); // write analog values to red, green and blue output pins
Here's a video of what I'm trying to accomplish
Thanks in advance!
