I am just getting into using an Arduino for a project and I went to upload the sketch onto the Arduino and I got this error
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xbe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xbe
Failed uploading: uploading error: exit status 1
Which board?
Which operating system?
Which version of the IDE?
Please enable verbose output during upload and disable verbose output during compilation in file/preferences in the IDE. Next perform an upload and post the results here.
Thanks for using code tags in your first post
You need to go into tools and set up for the proper board.
arduino nano
windows 10
IDE 2.3.2
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\willi\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM2
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x3f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x3f
avrdude done. Thank you.
Failed uploading: uploading error: exit status 1```
For the Nano, you have 3 options for the processor in the tools menu. Based on the output that you have provided you did choose the 328P option. Try the "old bootloader" option; although ai do not now for sure that you have a clone, most clones require that option. Some clones come with the 168 processor, so that is another option to try.
thank you the old bootloader option worked I wouldn't have even thought to try that
Even i am facing the same issue in aurdino nano. please solve this problem i tried to check the board name and also the port name i have choosen correctly and have selected "old bootloader" but even then i find this error so please try to solve my problem.
Hi @1shobitha_bc. You described the Arduino board you are uploading to as "Nano". Something that can be confusing is there are multiple boards with "Nano" in their name. We need to be certain of exactly which one you have. The reason is that the problem might be caused by the IDE not being correctly configured for your specific board.
Please tell us which of the following boards you are attempting to upload to:
If you aren't sure which one you have, you can provide a picture of the board or a link to the place you bought it from and we'll see if we can identify it.
