It comiles just fine but when i upload it to my arduino nano it just spits out
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xaf
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xaf
Problem beim Hochladen auf das Board. Hilfestellung dazu unter http://www.arduino.cc/en/Guide/Troubleshooting#upload.
Uncheck the checkbox next to "Show verbose output during: compilation"
Check the checkbox next to "Show verbose output during: upload
Click "OK"
Sketch > Upload
After the upload fails, you'll see a button on the right side of the orange bar "Copy error messages" (or the icon that looks like two pieces of paper at the top right corner of the black console window in the Arduino Web Editor). Click that button.
In a forum reply here, click on the reply field.
Click the </> button on the forum toolbar. This will add the forum's code tags markup to your reply.
Press "Ctrl + V". This will paste the upload output between the code tags.
Move the cursor outside of the code tags before you add any additional text to your reply.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 16278 bytes (52%) of program storage space. Maximum is 30720 bytes.
Global variables use 612 bytes (29%) of dynamic memory, leaving 1436 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b57600 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_296756/Stage_1_3.0.ino.hex:i
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x4c
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x4c
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in C:\Users\user\Documents\Arduino\libraries\Arduino: no headers files (.h) found in C:\Users\user\Documents\Arduino\libraries\Arduino
option enabled in File -> Preferences.
Arduino: 1.8.9 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM7 -b115200 -D -Uflash:w:C:\Users\user\AppData\Local\Temp\arduino_build_19318/Stage_1_3.0.ino.hex:i
Using Port : COM7
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x8d
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x8d
If you have an official Arduino Nano made by Arduino that you bought in 2018 or 2019 then you should select Tools > Processor > ATmega328P. If you have an official Nano bought before 2018 or a Nano made by any company other than Arduino then you should select Tools > Processor > ATmega328P (Old Bootloader). Clearly there's some other problem, but having the wrong Tools > Processor item selected will also cause the upload to fail so it's important that you have the correct selection from that menu in addition to fixing whatever the other problem is causing the upload to fail.
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
If you don’t know which port is your Arduino, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
