As boldened in my post #9:
http://drazzy.com/package_drazzy.com_index.json
Agreed, I'm 101% convinced! Thanks for the QED ![]()
Answering your earlier question: my own sketch (working on UNO) failed on compile to ATTiny88. Looking at the verbose report it seems to be down to RTClib somehow? Obscure to me. I'll paste the full report .
I also note a warning about low memory. While not the cause of failure, that may well prompt me to abandon the present time-consuming quest. And instead just restrict usage of my four Tiny boards to relatively trivial sketches.
I'll try reproducing your steps later today.
Arduino: 1.8.19 (Windows 10), Board: "ATtiny88/48 (No Bootloader), -Os (size, recommended), ATtiny88, 8 MHz (internal), Standard, EEPROM retained, RX on PD7, TX on PD (default PD6), B.O.D. Disabled (saves power), Enabled"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\terry\AppData\Local\Arduino15\packages -hardware C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\terry\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries -fqbn=ATTinyCore:avr:attinyx8:optimization=size,chip=88,clock=internal_8m,pinmap=default,eesave=aenable,softserial=enable,bod=disable,millis=enabled -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\terry\AppData\Local\Temp\arduino_build_952333 -warnings=all -build-cache C:\Users\terry\AppData\Local\Temp\arduino_cache_781752 -prefs=build.warn_data_percentage=75 -verbose C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\MY SKETCHES\LCD_etc\LCD-RTClib-Tiny\LCD-RTClib-Tiny.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\terry\AppData\Local\Arduino15\packages -hardware C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\terry\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries -fqbn=ATTinyCore:avr:attinyx8:optimization=size,chip=88,clock=internal_8m,pinmap=default,eesave=aenable,softserial=enable,bod=disable,millis=enabled -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\terry\AppData\Local\Temp\arduino_build_952333 -warnings=all -build-cache C:\Users\terry\AppData\Local\Temp\arduino_cache_781752 -prefs=build.warn_data_percentage=75 -verbose C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\MY SKETCHES\LCD_etc\LCD-RTClib-Tiny\LCD-RTClib-Tiny.ino
Using board 'attinyx8' from platform in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr
Using core 'tiny' from platform in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@2.0.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@2.0.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o nul
Alternatives for LiquidCrystal_I2C.h: [LiquidCrystal_I2C@1.1.2]
ResolveLibrary(LiquidCrystal_I2C.h)
-> candidates: [LiquidCrystal_I2C@1.1.2]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o nul
Alternatives for RTClib.h: [RTClib@2.1.3]
ResolveLibrary(RTClib.h)
-> candidates: [RTClib@2.1.3]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o nul
Alternatives for Adafruit_I2CDevice.h: [Adafruit_BusIO@1.16.0]
ResolveLibrary(Adafruit_I2CDevice.h)
-> candidates: [Adafruit_BusIO@1.16.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\USI_TWI_Master\\USI_TWI_Master.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\USI_TWI_Slave\\USI_TWI_Slave.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\Wire.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\WireS.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\twi.c" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_I2C.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_DS1307.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_DS3231.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_Micros.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_Millis.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_PCF8523.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_PCF8563.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTClib.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
Alternatives for SPI.h: [SPI@2.0.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@2.0.0]
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o nul
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI\\SPI.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -mrelax -w -x c++ -E -CC -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp.o"
Compiling libraries...
Compiling library "Wire"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\twi.c" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\twi.c.o"
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire\src\twi.c: In function '__vector_19':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire\src\twi.c:430:49: warning: this statement may fall through [-Wimplicit-fallthrough=]
twi_masterBuffer[twi_masterBufferIndex++] = TWDR;
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire\src\twi.c:431:5: note: here
case TW_MR_SLA_ACK: // address sent, ack received
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire\src\twi.c:512:10: warning: this statement may fall through [-Wimplicit-fallthrough=]
if (0 == twi_txBufferLength) {
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire\src\twi.c:517:5: note: here
case TW_ST_DATA_ACK: // byte sent, ack returned
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\Wire.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\Wire.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\WireS.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\WireS.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\USI_TWI_Master\\USI_TWI_Master.c" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\USI_TWI_Master\\USI_TWI_Master.c.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -c -g -Os -Wall -Wextra -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mrelax -Werror=implicit-function-declaration -Wundef -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src\\USI_TWI_Slave\\USI_TWI_Slave.c" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\USI_TWI_Slave\\USI_TWI_Slave.c.o"
Compiling library "LiquidCrystal_I2C"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_I2C.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_I2C.cpp.o"
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::begin(uint8_t, uint8_t, uint8_t)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:66:39: warning: unused parameter 'cols' [-Wunused-parameter]
void LiquidCrystal_I2C::begin(uint8_t cols, uint8_t lines, uint8_t dotsize) {
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::setDelay(int, int)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:307:39: warning: unused parameter 'cmdDelay' [-Wunused-parameter]
void LiquidCrystal_I2C::setDelay (int cmdDelay,int charDelay) {}
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:307:52: warning: unused parameter 'charDelay' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'uint8_t LiquidCrystal_I2C::init_bargraph(uint8_t)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:310:50: warning: unused parameter 'graphtype' [-Wunused-parameter]
uint8_t LiquidCrystal_I2C::init_bargraph(uint8_t graphtype){return 0;}
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::draw_horizontal_graph(uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:311:55: warning: unused parameter 'row' [-Wunused-parameter]
void LiquidCrystal_I2C::draw_horizontal_graph(uint8_t row, uint8_t column, uint8_t len, uint8_t pixel_col_end){}
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:311:68: warning: unused parameter 'column' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:311:84: warning: unused parameter 'len' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:311:98: warning: unused parameter 'pixel_col_end' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::draw_vertical_graph(uint8_t, uint8_t, uint8_t, uint8_t)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:312:53: warning: unused parameter 'row' [-Wunused-parameter]
void LiquidCrystal_I2C::draw_vertical_graph(uint8_t row, uint8_t column, uint8_t len, uint8_t pixel_row_end){}
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:312:66: warning: unused parameter 'column' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:312:82: warning: unused parameter 'len' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:312:96: warning: unused parameter 'pixel_row_end' [-Wunused-parameter]
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp: In member function 'void LiquidCrystal_I2C::setContrast(uint8_t)':
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C\LiquidCrystal_I2C.cpp:313:45: warning: unused parameter 'new_val' [-Wunused-parameter]
void LiquidCrystal_I2C::setContrast(uint8_t new_val){}
Compiling library "RTClib"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_Millis.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_Millis.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_PCF8523.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_PCF8523.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTClib.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTClib.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_DS1307.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_DS1307.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_DS3231.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_DS3231.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_PCF8563.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_PCF8563.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src\\RTC_Micros.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_Micros.cpp.o"
Compiling library "Adafruit_BusIO"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o"
Compiling library "SPI"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -Wall -Wextra -std=gnu++17 -fpermissive -Wno-sized-deallocation -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mrelax -mmcu=attiny88 -DF_CPU=8000000UL -DCLOCK_SOURCE=0 -DARDUINO=10819 -DARDUINO=10819 -DARDUINO_AVR_ATTINYX8 -DARDUINO_ARCH_AVR "-DATTINYCORE=\"2.0.0-dev\"" -DATTINYCORE_MAJOR=2UL -DATTINYCORE_MINOR=0UL -DATTINYCORE_PATCH=0UL -DATTINYCORE_RELEASED=0 "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\cores\\tiny" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\variants\\tinyx8" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\Wire\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\LiquidCrystal_I2C" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\RTClib\\src" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\libraries\\Adafruit_BusIO" "-IC:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI" "C:\\Users\\terry\\Dropbox\\Electronics\\Arduino\\SKETCHES\\Hardware\\ATTinyCore\\avr\\libraries\\SPI\\SPI.cpp" -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\SPI\\SPI.cpp.o"
Compiling core...
Using precompiled core: C:\Users\terry\AppData\Local\Temp\arduino_cache_781752\core\core_eef64197420e4c07adb47335f68d5f84.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -Wall -Wextra -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mrelax -mmcu=attiny88 -o "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\sketch\\LCD-RTClib-Tiny.ino.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\twi.c.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\WireS.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\USI_TWI_Master\\USI_TWI_Master.c.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Wire\\USI_TWI_Slave\\USI_TWI_Slave.c.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\LiquidCrystal_I2C\\LiquidCrystal_I2C.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_DS1307.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_DS3231.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_Micros.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_Millis.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_PCF8523.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTC_PCF8563.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\RTClib\\RTClib.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_BusIO_Register.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_I2CDevice.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\Adafruit_BusIO\\Adafruit_SPIDevice.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/..\\arduino_cache_781752\\core\\core_eef64197420e4c07adb47335f68d5f84.a" "-LC:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf" "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.hex"
cmd /C "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objdump" --disassemble --source --line-numbers --demangle --section=.text "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf" > "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.lst"
cmd /C "C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-nm" --numeric-sort --line-numbers --demangle --print-size --format=s "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf" > "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.map"
Using library Wire at version 2.0.0 in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire
Using library LiquidCrystal_I2C at version 1.1.2 in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\LiquidCrystal_I2C
Using library RTClib at version 2.1.3 in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\RTClib
Using library Adafruit_BusIO at version 1.16.0 in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\libraries\Adafruit_BusIO
Using library SPI at version 2.0.0 in folder: C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\SPI
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\terry\\AppData\\Local\\Temp\\arduino_build_952333/LCD-RTClib-Tiny.ino.elf"
Sketch uses 4814 bytes (58%) of program storage space. Maximum is 8192 bytes.
Global variables use 473 bytes (92%) of dynamic memory, leaving 39 bytes for local variables. Maximum is 512 bytes.
Low memory available, stability problems may occur.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
There is nothing surprising in that - the Tiny family controllers doesn't have a I2c interface. It use an USI instead.
Therefore the Wire library in the code is just a emulation, which may not be fully compatible between platforms.
Another problem - If the library code uses low-level i2c methods, this library will not work on Tiny.
Thanks. Looks like another reason to "...abandon the present time-consuming quest. And instead just restrict usage of my four Tiny boards to relatively trivial sketches."
Seems that I can get 'LCD only' sketches running, so at least I have a limited debugging facility, but even that appears inconsistent.
It looks like your core and library installation is still a mess. Why do you have a Hardware core in your SKETCHES folder???
Despite that, it actually did compile (although perhaps incorrectly because of your installation mess). It failed to upload to the board:
So, you likely have a programmer problem too.
Post the full code you tried to compile. I'll see if the log looks more promising on my installation. Specify exactly the libraries you're using, including version. Provide either a GitHub link or a screen shot of the library in Arduino's Library Manager.
Ok thanks. Iām away from PC but checking SKETCHES\libraries on my iPhone there is no Wire entry. As discussed up thread I deleted it a few days ago.
Presumably a folder ālibraries-30Janā where I kept some old backup is ignored?
The compiler sure sees a hardware core in your SKETCHES folder. It doesn't belong there!!!
At this point, I'll believe the compiler not your iPhone.
My \libraries folder is here, as configured in IDE > File > Preferences > Settings > Sketchbook location:
Not
Please answer my question .... why do you have a Hardware Core in your Sketchbook folder?
I can say with confidence that @Terrypin is doing neither. I've never seen a core installed via the Board Manager end up there.
It's not in my 'Sketchbook folder', as I showed you in post #31.
The core you described from the error report was :
C:\Users\terry\Dropbox\Electronics\Arduino\SKETCHES\Hardware\ATTinyCore\avr\libraries\Wire .
I didn't create it or any of its subfolders or files.
Where are the cores you installed located?
It's certainly under it:
See Post #23.
No, it's not, look again! Once more, see my post #31. Are you perhaps confused by the fact that the string 'SKETCHES' appears more than once on my PC?
Could be that I'm quite confused. I see this:
and this:
So if the former is your sketches folder as selected in preferences, then latter is under it. @Delta_G, says that's OK. But it certainly seemed odd for a core installed via Board Manager.
Yes, on seeing @Delta_G 's feedback I was a tad resassured that it wasn't just down to me! Can't remember the details (some months ago), but I did carefully follow the instructions on installing the core. And that's where it ended up. Clearly different in your case.
Thanks, that was certainly the guidance I recall - although I'm still unsure which option I took. I think I tried one, probably the Boards Manager, hit problems and successfully used the other.
Should I remove the Arduino boards first?
Reckon that blue breadboard must be at least 25 years old. Guess it's my age - I hate throwing stuff away.
The next time the breadboards are free, remove all components and clean in the cleaner.
Suggest 50% IPA, put breadboards in a plastic bag (to conserve IPA), emergency in 50° water.
Rinse with water, blow dry.
I still have my school day SK-10 breadboards from 1977.
The "new" TIny's (TinyAVR-0,1,2 aka "megaTiny" or "xTiny") (like ATtiny3217) , and avr-dd, avr-ea, etc (AVR16dd28) are much more capable. And generally cheaper, too.
I'm not sure if anyone has ported over the VUSB stuff, though.
