Problems with if/else counting without pause.
I tried to write a code to operate an automatic can crusher with an LCD readout so it can tell how many cans it has crushed. After designing the circuit and writing the code from examples I cannot get it to work--count the cans it crushes (if the number of switch count is divisabe by 2 one can has been crushed). Instead of counting the switch and seeing if it is a factor of 2, it just adds the number of cans without end.
Here is my code:
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2); // LCD on pins 12, 11, 10, 5, 4, 3, 2.
int StartPin = 13;                          // switch input
int motor1Pin = 7;                         // H-bridge leg 1 (pin 2, 1A)
int motor2Pin = 6;                         // H-bridge leg 2 (pin 7, 2A)
int enablePin = 8;                         // H-bridge enable pin
int DirPin = 1;                            // Motor direction select
//int DirState = 0;
int DirSwCounter = 0;
int LastDirState = LOW;
int Dir = LOW;
int cansCrushed = 0;                       // Initial number of cans crushed set to 0
  lcd.print("Can Crusher MKII");
  delay(3000);
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Crushed:");
  lcd.setCursor(10, 0);
  lcd.print((int)cansCrushed);
  lcd.setCursor(0, 1);
  lcd.print("Weight:");
  lcd.setCursor(9, 1);
  lcd.print((int)cansCrushed*.034375);
  pinMode(StartPin, INPUT);
  pinMode(DirPin, INPUT);
  pinMode(motor1Pin, OUTPUT);
  pinMode(motor2Pin, OUTPUT);
  pinMode(enablePin, OUTPUT);
  digitalWrite(enablePin, LOW);
int DirState = digitalRead(DirPin);
  if (DirState =! LastDirState){
     if (DirState == HIGH){
      DirSwCounter++;
  LastDirState = DirState;
if (DirSwCounter % 2 == 0){
  digitalWrite(Dir, LOW);
  cansCrushed++;
  digitalWrite(Dir, HIGH);
if (digitalRead(StartPin == HIGH) && digitalRead(Dir == LOW)){
digitalWrite(enablePin, HIGH);
digitalWrite(motor1Pin, HIGH);
digitalWrite(motor2Pin, LOW);
else if (digitalRead(StartPin == HIGH) && digitalRead(Dir == HIGH)){
  digitalWrite(motor2Pin, HIGH);
else {
Thanks,
matrhint
You're reading the wrong pins - sort out your parentheses.
please modify your post, select the code and press the # button
  delay(3000);
  lcd.begin(16, 2);
You print before you initialized the LCD, might work but counterintuitive
put this part in a separate function
void displayStatus()
  lcd.clear();
A quick look at your code with some changes
//int DirState = 0;
int Dir = LOW;              <<<<< THIS IS NO PIN NUMBER
  // INITIALIZE
  // GET STARTED
  lcd.begin(16, 2);
  delay(3000);
  displayStatus();
  // READ PINS
  if (LastDirState == LOW && DirState == HIGH)  // you want to detect a rising edge
    DirSwCounter++;
  // PROCESS
    digitalWrite(Dir, LOW);     // SEE ABOVE -  int Dir = LOW;  CONFLICT !!! Dir should be initialized to a pinnumber e.g.!!!
    cansCrushed++;
  // if (digitalRead(StartPin == HIGH) && digitalRead(Dir == LOW))  // FAULT. you mean probably
  if (digitalRead(StartPin) == HIGH && digitalRead(Dir == LOW)
  // else if (digitalRead(StartPin == HIGH) && digitalRead(Dir == HIGH))  // FAULT. you mean probably
  else if (digitalRead(StartPin) == HIGH && digitalRead(Dir) == HIGH)
  displayStatus();
For pins that don't need to change you better use
#define DIRPIN 1 iso int dirPin=1; as the latter can be changed. you can just do int x = digitalRead(DIRPIN);
hopes this helps
Thanks guys! I can't wait to try it out!
It gives me a error with the displayStatus(); in the setup and loop, and I see how I messed up with the parentheses. I took out the displayStatus();.
Thanks alot agin for your help.
