Problems with IF statement (Arduino UNO)
Hello! I have a problem with my code, and I I`m a newbie in in the language the Arduino use.
I just wanted to make a LED show, to test the Arduino.
I tried to make a binary counter, witch have been successfully.
Then I tried to make it "mirrored". But seems to not work so well.
Original code (works!):
  Binary counter by BlackPaw
 created 2014
 by BlackPaw
 created 17 Jan 2014
 modified 20 Jan 2014
 by BlackPaw
// constants won't change. They're used here to
// set pin numbers:
const int buttonPin = 12;     // the number of the pushbutton pin
const int ledPin1 =  2;      // the number of the LED1 pin
const int ledPin2 =  3;     // the number of the LED2 pin
const int ledPin3 =  4;     // the number of the LED3 pin
const int ledPin4 =  5;     // the number of the LED4 pin
const int ledPin5 =  6;     // the number of the LED5 pin
const int ledPin6 =  7;     // the number of the LED6 pin
const int ledPin7 =  8;     // the number of the LED7 pin
const int ledPin8 =  9;     // the number of the LED8 pin
// variables will change:
int buttonState = 0;         // variable for reading the pushbutton status
int led1 = 1;
int led2 = 2;
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
int led8 = 8;
  pinMode(ledPin1, OUTPUT);
  pinMode(ledPin2, OUTPUT);
  pinMode(ledPin3, OUTPUT);
  pinMode(ledPin4, OUTPUT);
  pinMode(ledPin5, OUTPUT);
  pinMode(ledPin6, OUTPUT);
  pinMode(ledPin7, OUTPUT);
  pinMode(ledPin8, OUTPUT);
  pinMode(buttonPin, INPUT);
void loop(){
 start:
  led1 = digitalRead(ledPin1);
  if (led1 == LOW) {
    digitalWrite(ledPin1, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin1, LOW);
  led2 = digitalRead(ledPin2);
  if (led2 == LOW) {
    digitalWrite(ledPin2, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin2, LOW);
  led3 = digitalRead(ledPin3);
  if (led3 == LOW) {
    digitalWrite(ledPin3, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin3, LOW);
  led4 = digitalRead(ledPin4);
  if (led4 == LOW) {
    digitalWrite(ledPin4, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin4, LOW);
  led5 = digitalRead(ledPin5);
  if (led5 == LOW) {
    digitalWrite(ledPin5, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin5, LOW);
  led6 = digitalRead(ledPin6);
  if (led6 == LOW) {
    digitalWrite(ledPin6, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin6, LOW);
  led7 = digitalRead(ledPin7);
  if (led7 == LOW) {
    digitalWrite(ledPin7, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin7, LOW);
  led8 = digitalRead(ledPin8);
  if (led8 == LOW) {
    digitalWrite(ledPin8, HIGH);
    delay(250);
    goto start;
  else {
    digitalWrite(ledPin8, LOW);
    delay(250);
and here is the mirrored code (does not work):
 created 2014
 by BlackPaw
 created 17 Jan 2014
 by BlackPaw
// set pin numbers:
const int ledPin1 =  2;      // the number of the LED pin
int led1 = 1;
int led2 = 2;
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
int led8 = 8;
void loop(){
 start2:
  if (led8 == LOW) {
    goto start2;
  else {
  if (led7 == LOW) {
    goto start2;
  else {
  if (led6 == LOW) {
    goto start2;
  else {
  if (led5 == LOW) {
    goto start2;
  else {
  if (led4 == LOW) {
    goto start2;
  else {
I cannot seem to find the error, tried to remake it over and over again.
I know there is many other ways to do this, but I only wanted to make a simple program to understand Arduino programming language.
Here`s a picture of the wireupp:
Regards - BlackPaw
Arrays! Arrays are your friend.
int led1 = 1;
int led2 = 2;
int led3 = 3;
int led4 = 4;
int led5 = 5;
int led6 = 6;
int led7 = 7;
int led8 = 8;
Why the weird initial values? Arrays! Arrays are your friend.
 start2:
May I introduce you to another friend, the delete key? Kick this label to hell and beyond, along with the goto statement that goes with it. The loop() function already loops. That's why it's called loop().
What does "mirrored" mean?
Sure it does. It just doesn't do what you want. But, you haven't described what it actually does, or what you want it to do.
After getting rid of the gotos, the odd initial values, and using arrays, your code will boil down to about 20 lines. Far easier to understand, debug, and modify. And explain.
blackpaw:
You're trying to Read from a pin that's been set as an output!
Instead use a boolean (true or false) variable to keep track of what state the pin is in.
That works. Not too common, since you can keep track of what you last wrote to the pin, but it's not wrong.
Brave fellow, publishing C code with a goto in it.
This is a commendable goal, but to achieve it, you really need to go with the flow and actually use the Arduino language in a conventional manner.
You can stick with writing Basic ( or whatever language it is, that you learned before ) with a few extra semicolons, but if you do, you'll have trouble understanding other examples of conventional arduino code, and other people will have trouble understanding yours.
