Hi guys
I new arduino user and I m making a programm to control DC motor from IR remote controller.
Everything goes well. But I have a problem when I send the command for a directoion to the motors, they don't stop, motors keep wheeling untils I sent another command. But what I want is the motors to wheel jujst for 1 second and then stop.
Here is the programm.
#include "IRremote.h"
#include "SR04.h"
#define ENABLE_RIGHT 5
#define DIRA_RIGHT 3
#define DIRB_RIGHT 4
#define ENABLE_LEFT 6
#define DIRA_LEFT 7
#define DIRB_LEFT 8
#define TRIG_PIN 12
#define ECHO_PIN 11
SR04 sr04 = SR04(ECHO_PIN, TRIG_PIN);
int receiver = 10; // Signal Pin of IR receiver to Arduino Digital Pin 11
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
long distance;
long MOVE_SIDE_DURATION = 500;
long MOVE_FORWARD_DURATION = 500;
long MOVE_BACKWARD_DURATION = 500;
long COMPUTE_DISTANCE_DURATION = 200;
long STOP_DURATION = 50;
//---set pin direction
pinMode(ENABLE_RIGHT, OUTPUT);
pinMode(DIRA_RIGHT, OUTPUT);
pinMode(DIRB_RIGHT, OUTPUT);
pinMode(ENABLE_LEFT, OUTPUT);
pinMode(DIRA_LEFT, OUTPUT);
pinMode(DIRB_LEFT, OUTPUT);
irrecv.enableIRIn(); // Start the receiver
irrecv.blink13(true);
void stopMotors() {
Serial.println("Stop motors");
digitalWrite(ENABLE_LEFT, HIGH);
digitalWrite(DIRA_LEFT, LOW);
digitalWrite(DIRB_LEFT, LOW);
digitalWrite(ENABLE_RIGHT, HIGH);
digitalWrite(DIRA_RIGHT, LOW);
digitalWrite(DIRB_RIGHT, LOW);
delay(STOP_DURATION);
void left() {
//move to left
Serial.println("Move to the left");
//analogWrite(ENABLE_RIGHT,255); //enable on
digitalWrite(ENABLE_RIGHT, HIGH); // enable on
digitalWrite(DIRA_RIGHT, LOW); //one way
digitalWrite(DIRB_RIGHT, HIGH);
digitalWrite(ENABLE_LEFT, HIGH); // enable on
digitalWrite(DIRA_LEFT, HIGH); //one way
delay(MOVE_SIDE_DURATION);
void right() {
//move to right
Serial.println("Move to the right");
digitalWrite(DIRA_RIGHT, HIGH); //one way
digitalWrite(DIRA_LEFT, LOW); //one way
digitalWrite(DIRB_LEFT, HIGH);
void forward() {
//move forward
Serial.println("Move forward");
delay(MOVE_FORWARD_DURATION);
void backward() {
//move backward
Serial.println("Move backward");
delay(MOVE_BACKWARD_DURATION);
boolean wayIsFree()
distance = sr04.Distance();
Serial.println("distance");
Serial.print(distance);
Serial.println("cm");
delay(COMPUTE_DISTANCE_DURATION);
if (distance > 30)
return true;
else {
return false;
if (irrecv.decode(&results)) // have we received an IR signal?
switch (results.value)
case 0xFFA25D: Serial.println("POWER"); {
wayIsFree();
case 0xFFE21D: Serial.println("FUNC/STOP"); {
stopMotors();
case 0xFF629D: Serial.println("VOL+"); {
forward();
stopMotors();
case 0xFF22DD: Serial.println("FAST BACK"); {
left();
stopMotors();
case 0xFFC23D: Serial.println("FAST FORWARD"); {
right();
stopMotors();
case 0xFFA857: Serial.println("VOL-"); {
backward();
stopMotors();
default:
Serial.println(" other button ");
irrecv.resume(); // receive the next value
