Problems with micros() function
I am having issues using the micros() function with
the nano 33 BLE.
Below is the data on the version of IDE I am using:
Version: 2.1.0
Date: 2023-04-19T15:31:10.185Z
CLI Version: 0.32.2
Copyright © 2023 Arduino SA
My sketch is very involved.
Therefore, I have submitted a sketch which shows the
problem with minimal code.
What I am basically trying to implement is an off-delay timer
to be used as a screen saver to prevent damage to my OLEDs.
The falling edge of PB(pin 4) triggers the ISR.
It sets the “SCREEN_SAVER_ELAPSED_MICROS” =0.
This is the current value.
This variable then counts up and should turn off the
LED after ten seconds. (10000000)
Pulsing PB resets ELAPSED_MICROS=0.
The problem I am having is that the LED stays on for about 14.4 sec.
To make things even more confusing, if I unremark the delay(1)
on line 57 the time is pretty close.(10 sec)
Any code I add (print,display,etc) changes the timing error.
So I can’t really troubleshoot using the monitor.
I have scope pictures if interested.
There doesn’t seem to be any contact bounce on the PB.
I’m sure I’m doing something wrong but don’t have a clue.
Please don’t ask me to try millis().
Here is the code:
Thanks,
Larry
//2023-06-21
//Minimal Code test micros() problem
#define  irq_pin         4
#define LEDPIN 10
#define TONEPIN 9  // Used if you want audio via a small buzzer
uint32_t       SCREEN_SAVER_ELAPSED_MICROS;
const uint32_t SCREEN_SAVER_THR_MICROS = 10000000;   //10 sec threshold
uint32_t       SCREEN_SAVER_OLD_MICROS = 0;
uint32_t       SCREEN_SAVER_DELTA_MICROS;
bool           SCREEN_SAVER_ACTIVE;
pinMode(4, INPUT_PULLUP);        //IRQ PIN
pinMode(10,OUTPUT);              //LED 4
// ========================= Global data definitions =====================
  Serial.begin(57600);
  attachInterrupt(irq_pin, ps2interrupt, FALLING);
} //end setup
// The ISR for the external interrupt
void ps2interrupt()   //driven by PB
  digitalWrite(10,HIGH); // Turn on L.E.D.
  SCREEN_SAVER_ELAPSED_MICROS=0; //resets screen saver
     SCREEN_SAVER();  //DO  screen saver calculations
}  //END of loop
void SCREEN_SAVER(){
  //delay(1);
if (SCREEN_SAVER_ELAPSED_MICROS >SCREEN_SAVER_THR_MICROS ){
     SCREEN_SAVER_OLD_MICROS = micros(); //keep track of micros even when screen save is active
     return;  //don't do calculatioins if already in saver mode
if(SCREEN_SAVER_ACTIVE & (SCREEN_SAVER_ELAPSED_MICROS==0 ) ) {  //SCREEN_SAVER_ELAPSED_MICROS SET=0 BY ISR
  SCREEN_SAVER_ACTIVE = false;
  return;
//ACCUMALATE TIME
if (micros()>SCREEN_SAVER_OLD_MICROS) {
    (SCREEN_SAVER_DELTA_MICROS = micros() - SCREEN_SAVER_OLD_MICROS );
    (SCREEN_SAVER_ELAPSED_MICROS = SCREEN_SAVER_ELAPSED_MICROS + SCREEN_SAVER_DELTA_MICROS);
    (SCREEN_SAVER_OLD_MICROS = micros()  );
if(SCREEN_SAVER_ELAPSED_MICROS >SCREEN_SAVER_THR_MICROS ) {
  SCREEN_SAVER_ACTIVE = true;
  digitalWrite(10,LOW); //
  return;
} // end of SCREEN_SAVER()
For a 10s delay why use micros()? millis() would be better and you only need to count 10,000 of them. Also I'm not sure quite how accurate micros() is though it might not be significant for you.
I'm not going to try and figure out the logic of your SCREEN_SAVED() function, just want to comment that it would be much easier to save the current value of micros() in the ISR, then use
if ((micros() - SCREEN_SAVER_ELAPSED_MICROS) >= 10000000)
to test if 10 seconds have elapsed.
I'm not sure what you are using to trigger the ISR, but if it is a switch it would probably work fine to just poll the switch in the code and eliminate the complications of using an interrupt.
In the real project the clock pulse from a keypoard is
triggering the interrupt.
Thanks for your time.
Larry
I need to use an interrupt because in the real project the clock
pulse from the PS2 keyboard is triggering the calculations.
Thanks,
Larry
Delta_G,
Unfortunately changing to volatile did not work.
I even set a bit in the ISR and used it in SCREEN_SAVER() to
reset the elapsed counts.
That did not work either.
Thanks for your thoughts.
I was sure that that was the problem.
What are "critical sections" and how do I get me some?
Thanks,
Larry
jhaine,
Thanks for the reply.
Are you saying there is a bug in the micros() function?
Later,
Larry
Not at all. Just that measuring a non-critical 10s delay with something with a nominal resolution of 1us is like measuring 10km with a 1mm long yardstick. The millis function will do the job just fine. I'm not sure about the nano33BLE but on the Uno and Nano also the granularity of micros() is also 4 usec.
I didn't know if I should create a new topic or add to this one.
After some investigation I've discovered that both millis() and micros() exhibit
the same problem.
In the attached code line 48 is delay(1).
If that line is included both millis() & micros() time correctly.
If it is not included both millis() & micros() time too long by about (2x).
Actually 3.92 sec vs 2.0 sec.
This was measured by a scope.
The interrupt is gone.
The extra method is gone.
Everything is done in "loop()".
Why is the timing wrong?
Thanks,
Larry
//2023-06-21
#define LEDPIN 10
volatile uint32_t       SCREEN_SAVER_ELAPSED_MICROS ;
const uint32_t          SCREEN_SAVER_THR_MICROS = 1000000;   //1.00 sec threshold, therefore 2 sec waveform period
uint32_t                SCREEN_SAVER_DELTA_MICROS = 0;
uint32_t                DUMMY;   //used to add meaningless processor steps
} //end setup
//delayMicroseconds(5);
   delay(1);
//ACCUMALATE TIME
  digitalWrite(10,!digitalRead(10)); //
  SCREEN_SAVER_ELAPSED_MICROS = 0;
}  //END of loop
Looks to be related to calling micros() twice in these lines of code, the slight difference in value for micros() is causing you to lose time. The 1mS delay greatly decreases how many time this code gets executed, so minimizes the accumulated error. If you set a variable to the value of micros(), then use that in these lines of code, the timing error goes away.
I'll ask again, why not just use the conventional method of millis / micros timing, instead of the rather convoluted method you are using?
#define LEDPIN 10
  pinMode(10, OUTPUT);             //LED 4
  SCREEN_SAVER_ELAPSED_MICROS = micros();
} //end setup
  if ((micros() - SCREEN_SAVER_ELAPSED_MICROS) >= SCREEN_SAVER_THR_MICROS ) {
    digitalWrite(10, !digitalRead(10)); //
    SCREEN_SAVER_ELAPSED_MICROS += SCREEN_SAVER_THR_MICROS; //increments target time by exactly SCREEN_SAVER_THR_MICROS
    //Serial.println(millis());
}  //END of loop
I don't understand what your "accumulate time" code is doing, or where you got that something should be two seconds, which the code has 1e6 microseconds as its constant.
micros() can be quite slow on mbed-based systems, because of all the layering involved in using the OS (on an rp2040, a call to micros() takes about 4us!) That could cause problems if not accounted for (ie micros() - micros() will give about 4, but takes 8us.)
I'm not sure how the 33BLE compares to an rp2040.
The first line is calculating the number of microseconds since the value of micros() was saved in the last iteration of loop().
The second line adds this amount to the accumulated time interval.
The last line saves the current micros() for use in the next loop.
The problem the OP is currently having is caused by the amount of time between the first line of code and the third line. There appears to be slightly less than 50% chance for the incrementing of the micros count to occur during this time, resulting in time passing but not being included in the accumulated time interval.
David,
You are a GENIUS!
I never would have thought that one instruction cycle would have made that much difference.
Your solution also solved the problem using millis().
How do I flag this topic as SOLVED?
Thanks again,
Larry
David,
I did not know there was a conventional method.
Where can I research it?
Thanks again,
Larry
David,
In my old life I spent much time programing industrial controlers.
Their operating system would load all global variables into a buffer
and use the buffered value. At the end of the scan it would then update
the global variables. It was called Load, Compute, Dump.
My mind was still working in the LoadComputeDump mode!
Thanks again,
Larry
You can look at the BlinkWithoutDelay example sketch, that is almost exactly what you are doing in your test code.
Delta_G,
You are 200% correct.
I'm sorry for posting incorrect info.
Thanks for the correction.
Larry
