Hi! I have a display (oled 128x64, 4pin). I using the OLED_I2C library by Rinky Dink Electronics (OLED_I2C - Rinky-Dink Electronics). Its work very good. However, when i try using a custom fonts (Rinky-Dink Electronics), i get this
Code:
pylon:
Just to check that too: if you use the default font, the text is displayed correctly, isn't it?
I am resolved my issue. Its simple. I downloaded the UTFT fonts. Its wrong. The my oled display is monochrome. I converted the .png file to the font. That helped. Thank you very match.
i thought the OLED_I2C library uses the UTFT fonts, at least the format in the source code looks the same to me. How did you convert the PNG into a format usable by the OLED_I2C Library?
