I have an Arduino UNO and an Ethernet shield and I am desperately looking for a sketch that can read tweets and with these turn on or off an output of the Arduino. I have tried with this sketch: https://www.arduino.cc/en/Tutorial/TwitterClient. But it doesn't seem to work, it is also written in "TwitterClient Tutorial" that Twitter has changed the authentication mode.
If have also tried with his code:
TweetLED Code
This code is based on the code made by Tom Igoe and is used in episode 3 of the Mike's Lab Series on Youtube.
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x01 };
IPAddress ip(192,168,1,20);
// initialize the library instance:
EthernetClient client;
const int requestInterval = 30000; // delay between requests
char serverName[] = "api.twitter.com"; // twitter URL
boolean requested; // whether you've made a request since connecting
long lastAttemptTime = 0; // last time you connected to the server, in milliseconds
String currentLine = ""; // string to hold the text from server
String tweet = ""; // string to hold the tweet
boolean readingTweet = false; // if you're currently reading the tweet
// reserve space for the strings:
pinMode(7,OUTPUT);
pinMode(8,OUTPUT);
currentLine.reserve(256);
tweet.reserve(150);
// initialize serial:
// attempt a DHCP connection:
if (!Ethernet.begin(mac)) {
// if DHCP fails, start with a hard-coded address:
Ethernet.begin(mac, ip);
// connect to Twitter:
connectToServer();
if (client.connected()) {
if (client.available()) {
// read incoming bytes:
char inChar = client.read();
// add incoming byte to end of line:
currentLine += inChar;
// if you get a newline, clear the line:
if (inChar == '\n') {
currentLine = "";
// if the current line ends with <text>, it will
// be followed by the tweet:
if ( currentLine.endsWith("<text>")) {
// tweet is beginning. Clear the tweet string:
readingTweet = true;
tweet = "";
// if you're currently reading the bytes of a tweet,
// add them to the tweet String:
if (readingTweet) {
if (inChar != '<') {
tweet += inChar;
else {
// if you got a "<" character,
// you've reached the end of the tweet:
Serial.println(tweet);
// close the connection to the server:
client.stop();
else if (millis() - lastAttemptTime > requestInterval) {
// if you're not connected, and two minutes have passed since
// your last connection, then attempt to connect again:
connectToServer();
if(tweet==">ledon")
digitalWrite(8,HIGH);
else if(tweet==">ledoff"){
digitalWrite(8,LOW);
void connectToServer() {
// attempt to connect, and wait a millisecond:
Serial.println("Connecting to server");
if (client.connect(serverName, 80)) {
Serial.println("Making HTTP Request");
// make HTTP GET request to twitter:
client.println("GET /1/statuses/user_timeline.xml?screen_name=mpieters95&count=1 HTTP/1.1");
client.println("HOST: api.twitter.com");
client.println();
// note the time of this connect attempt:
lastAttemptTime = millis();
I can't find another sketch that works for me.
If you can help me it will be very appreciated. Thanks!
