I’m giving rotary encoders a go, but running into problems where when I turn the rotary encoder left or right, nothing is registering in the serial monitor at all.
I have a 3 pin rotary encoder (this one: Rotary Encoder - 20 step 20-step Rotary Encoder [ST079] - £1.19 : Bitsbox Electronic Components, Electronic Component Suppliers UK) I have connected up using a similar method to the one in this example: How to Build a Rotary Encoder Circuit with an Arduino
I have Pin 1 (left-hand pin) of the rotary encoder directly connected to D6 on the D1 mini and Pin 3 (right-hand pin) of the rotary encoder connected to D7 on the D1 Mini. Pin 2 (middle pin) of the rotary encoder is connected to ground.
I’m using the example sketch below to test:
#include <Arduino.h>
//Rotary encoder example
int val;
int encoder0PinA = 13; // D7 on wemos d1 mini
int encoder0PinB = 12; // D6 on wemos d1 mini
int encoder0Pos = 0;
int encoder0PinALast = LOW;
int n = LOW;
pinMode (encoder0PinA, INPUT);
pinMode (encoder0PinB, INPUT);
Serial.begin (9600);
n = digitalRead(encoder0PinA);
if ((encoder0PinALast == LOW) && (n == HIGH)) {
if (digitalRead(encoder0PinB) == LOW) {
encoder0Pos--;
encoder0Pos++;
Serial.print (encoder0Pos);
Serial.print ("/");
encoder0PinALast = n;
