Problems with xbee.h v0.5
I'm having trouble getting my Xbee (Series 1) to communicate. They worked fine when I was using xbee.h library v0.4, but there was a change in v0.5 that's causing me problems. The v0.5 change has to do with serial setup, here's the release note for it.
Originally I started started xbee like this:
xbee.begin(9600);
With version 0.5, I'm supposed to do this (I think):
xbee.setSerial(Serial);
I'm not using soft serial, just hard serial.
Here's the xbee library diff comparison for the changes from 0.4 to 0.5: xbee.h, xbee.cpp
Below are the Rx and Tx sketches. Basically the two xbees are not able to communicate. The error from the transmitter sketch is: "XBee did not provide a timely Tx Status Response"
Receiver sketch:
#include <XBee.h>
#define PRINT_DEBUG       // comment out if you don't want anything to go to serial monitor
XBee xbee;
XBeeResponse response;
// create reusable response objects for responses we expect to handle
Rx16Response rx16;
  #ifdef PRINT_DEBUG
    Serial.println("Xbee Rx/Coordinator setup()");
  #endif
  uint8_t option;
  uint8_t signalStrength;
  uint8_t dataLength;
  static int16_t RxData[3];  // Array to hold data received
  uint16_t Tx_Id;            // Address of transmitter (MY ID)
    xbee.readPacket();
    if (xbee.getResponse().isAvailable())
      // got something
      #ifdef PRINT_DEBUG
        Serial.println("Got Something:");
      #endif
      if (xbee.getResponse().getApiId() == RX_16_RESPONSE )
        // got a Rx packet
        xbee.getResponse().getRx16Response(rx16);
        option = rx16.getOption();
        dataLength = rx16.getDataLength();
        Tx_Id = rx16.getRemoteAddress16();
        signalStrength = rx16.getRssi();
        for(int i=0; i < dataLength; i=i+2)
          RxData[i/2]  = rx16.getData(i) << 8;
          RxData[i/2] |= rx16.getData(i+1);
          #ifdef PRINT_DEBUG
            // Print data received (16-bit integers that have been divided into 2 bytes)
            Serial.println(RxData[i/2]);
          #endif
        #ifdef PRINT_DEBUG
          Serial.print("Transmitter MY address: ");
          Serial.println(rx16.getRemoteAddress16(), HEX);
          Serial.print("Signal strength = ");
          Serial.println(signalStrength);
          Serial.print("Data Length = ");
          Serial.print(dataLength);
          Serial.println(" bytes");
        #endif
      	// not something we were expecting
    else if (xbee.getResponse().isError())
    { // Got something, but not a packet
      #ifdef PRINT_DEBUG
        Serial.print("Error reading packet.  Error code: ");
        Serial.println(xbee.getResponse().getErrorCode());
      #endif
    } // End Got Something
      // xbee not available and no error
      #ifdef PRINT_DEBUG
        Serial.print("isAvailable(): ");
        Serial.println(xbee.getResponse().isAvailable());
      #endif
Transmitter sketch:
#include <XBee.h>
#define MY_ADDR_RX 0x250
#define NUM_DATA_PTS   3
// allocate array to hold bytes to send to other xbee.  Size is 2x the number if integers being sent
uint8_t payload[NUM_DATA_PTS * 2];
XBee xbee;
// 16-bit addressing: Enter address of remote XBee, typically the coordinator
Tx16Request tx = Tx16Request(MY_ADDR_RX, payload, sizeof(payload));
TxStatusResponse txStatus;
  #ifdef PRINT_DEBUG
    Serial.println("Xbee Tx/End Node - setup()");
  #endif
    int16_t xbeeData[NUM_DATA_PTS];  // Array to hold integers that will be sent to other xbee
    // Test data to send to other xbee
    xbeeData[0] = 1234;
    xbeeData[1] = 5678;
    xbeeData[2] = -500;
    // break down integers into two bytes and place in payload
    for(int i=0; i<NUM_DATA_PTS; i++)
      payload[i*2]     = xbeeData[i] >> 8 & 0xff; // High byte - shift bits 8 places, 0xff masks off the upper 8 bits
      payload[(i*2)+1] = xbeeData[i] & 0xff;      // Low byte, just mask off the upper 8 bits
      #ifdef PRINT_DEBUG
        Serial.print("Data = ");
        Serial.print(xbeeData[i]);
        Serial.print(", payload high byte = ");
        Serial.print(payload[i*2]);
        Serial.print(", payload low byte = ");
        Serial.println(payload[(i*2)+1]);
      #endif
    xbee.send(tx);
    // after sending a tx request, we expect a status response
    // wait up to 5 seconds for the status response
    if (xbee.readPacket(5000))
        // got a response!
        #ifdef PRINT_DEBUG
          Serial.println("\nGot a response from receiver");
        #endif
        // should be a znet tx status
        if (xbee.getResponse().getApiId() == TX_STATUS_RESPONSE)
          xbee.getResponse().getZBTxStatusResponse(txStatus);
    	   // get the delivery status, 0 = OK, 1 = Error, 2 = Invalid Command, 3 = Invalid Parameter
          if (txStatus.getStatus() == SUCCESS)
            // success.  time to celebrate
            #ifdef PRINT_DEBUG
              Serial.println("Tx Succeeded");
            #endif
            // the remote XBee did not receive our packet. is it powered on?
            #ifdef PRINT_DEBUG
              Serial.print("\nTx Failed, xbee status = ");
              Serial.println(txStatus.getStatus());
            #endif
      #ifdef PRINT_DEBUG
        Serial.print("\nError reading packet.  Error code: ");
      #endif
      // local XBee did not provide a timely TX Status Response.  Radio is not configured properly or connected
      #ifdef PRINT_DEBUG
        Serial.println("\nXBee did not provide a timely Tx Status Response\n");
      #endif
    } // Finished waiting for XBee packet
I forgot to mention, one of my Xbees is used with a Leonardo, the other with an Mega. Since Leonardo uses serial differently, maybe this is part of the problem. Also, I'm using the xbees in API mode.
Okay, I figured it out. For my sketch that's running on a Leonardo, I need to use Serial1 instead of Serial, like this:
Serial1.begin(9600);
xbee.setSerial(Serial1);
