Processing + Arduino face tracking webcam port issue
I'm new to Processing and Arduino and trying to to work on face tracking pan and tilt system.
Processing and Arduino to control pan and tilt system with OpenCV and a webcam.
I have found this code online and it seems to work on with built-in Isight webcam, but when I plug in the external webcam, Processing can't seem to recognize the port and I get NullPointerException error.
import gab.opencv.*;
import processing.video.*;
import java.awt.*;
import processing.serial.*; //The serial library is needed to communicate with the Arduino.
Capture video;
OpenCV opencv;
//Screen Size Parameters
int width = 320;
int height = 240;
// contrast/brightness values
int contrast_value    = 0;
int brightness_value  = 0;
Serial port; // The serial port
//Variables for keeping track of the current servo positions.
char servoTiltPosition = 90;
char servoPanPosition = 90;
//The pan/tilt servo ids for the Arduino serial command interface.
char tiltChannel = 0;
char panChannel = 1;
//These variables hold the x and y location for the middle of the detected face.
int midFaceY=0;
int midFaceX=0;
//The variables correspond to the middle of the screen, and will be compared to the midFace values
int midScreenY = (height/2);
int midScreenX = (width/2);
int midScreenWindow = 10;  //This is the acceptable 'error' for the center of the screen.
//The degree of change that will be applied to the servo each time we update the position.
int stepSize=1;
  String[] cameras = Capture.list();
  size(width, height);
  video = new Capture(this, width/2, height/2, cameras[0]);
  opencv = new OpenCV(this, width/2, height/2);
  opencv.loadCascade(OpenCV.CASCADE_FRONTALFACE);
  video.start();
  port = new Serial(this, "/dev/tty.usbmodem411", 57600);   //Baud rate is set to 57600 to match the Arduino baud rate.
  //Send the initial pan/tilt angles to the Arduino to set the device up to look straight forward.
  port.write(tiltChannel);    //Send the Tilt Servo ID
  port.write(servoTiltPosition);  //Send the Tilt Position (currently 90 degrees)
  port.write(panChannel);         //Send the Pan Servo ID
  port.write(servoPanPosition);   //Send the Pan Position (currently 90 degrees)
void draw() {
  scale(2);
  opencv.loadImage(video);
  image(video, 0, 0 );
  noFill();
  stroke(0, 255, 0);
  strokeWeight(3);
  Rectangle[] faces = opencv.detect();
  println(faces.length);
  for (int i = 0; i < faces.length; i++) {
    println(faces[i].x + "," + faces[i].y);
    rect(faces[i].x, faces[i].y, faces[i].width, faces[i].height);
  //Find out if any faces were detected.
  if(faces.length > 0){
    //If a face was found, find the midpoint of the first face in the frame.
    //NOTE: The .x and .y of the face rectangle corresponds to the upper left corner of the rectangle,
    //      so we manipulate these values to find the midpoint of the rectangle.
    midFaceY = faces[0].y + (faces[0].height/2);
    midFaceX = faces[0].x + (faces[0].width/2);
 //Find out if the Y component of the face is below the middle of the screen.
    if (midFaceY > (midScreenY + midScreenWindow)) {
      if (servoTiltPosition >= 5)servoTiltPosition -= stepSize; //If it is below the middle of the screen, update the tilt position variable to lower the tilt servo.
    //Find out if the Y component of the face is above the middle of the screen.
    else if (midFaceY < (midScreenY - midScreenWindow)) {
      if (servoTiltPosition <= 175)servoTiltPosition +=stepSize; //Update the tilt position variable to raise the tilt servo.
    //Find out if the X component of the face is to the left of the middle of the screen.
    if(midFaceX < (midScreenX - midScreenWindow)){
      if(servoPanPosition >= 5)servoPanPosition -= stepSize; //Update the pan position variable to move the servo to the left.
    //Find out if the X component of the face is to the right of the middle of the screen.
    else if(midFaceX > (midScreenX + midScreenWindow)){
      if(servoPanPosition <= 175)servoPanPosition +=stepSize; //Update the pan position variable to move the servo to the right.
  //Update the servo positions by sending the serial command to the Arduino.
  port.write(tiltChannel);      //Send the tilt servo ID
  port.write(servoTiltPosition); //Send the updated tilt position.
  port.write(panChannel);        //Send the Pan servo ID
  port.write(servoPanPosition);  //Send the updated pan position.
    if(faces.length == 0){
  //delay(1);
void captureEvent(Capture c) {
  c.read();
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
servo_face_detect.ino (1.51 KB)
my_face_detection1.pde (4.37 KB)
Did you have an Arduino question?
@PaulS
the guy siad he's new and he mentioned Arduino. ?? so what is it that you are asking him???
So?
Your point being?
The post has a question about why Processing throws an exception when an external web cam is connected to the PC, and Processing is told to read that camera instead. There was nothing in the post about any problem with the Arduino. As far as we know, the Arduino is something that belongs to a neighbor of a cousin of a friend of the postman that delivered a package to a coworker's mother-in-law.
