processing ide
hi guys ia am new to arduino....
my second projectis arduino radar..
when i am processing my program in processing ide it gives me an eror
this is the programimport processing.serial.*; // imports library for serial communication
import java.awt.event.KeyEvent; // imports library for reading the data from the serial port
import java.io.IOException;
Serial myPort; // defines Object Serial
// defubes variables
String angle="";
String distance="";
String data="";
String noObject;
float pixsDistance;
int iAngle, iDistance;
int index1=0;
int index2=0;
PFont orcFont;
size (1920, 1080);
smooth();
myPort = new Serial(this,"COM4", 9600); // starts the serial communication
myPort.bufferUntil('.'); // reads the data from the serial port up to the character '.'. So actually it reads this: angle,distance.
orcFont = loadFont("OCRAExtended-30.vlw");
void draw() {
fill(98,245,31);
textFont(orcFont);
// simulating motion blur and slow fade of the moving line
noStroke();
fill(0,4);
rect(0, 0, width, 1010);
fill(98,245,31); // green color
// calls the functions for drawing the radar
drawRadar();
drawLine();
drawObject();
drawText();
void serialEvent (Serial myPort) { // starts reading data from the Serial Port
// reads the data from the Serial Port up to the character '.' and puts it into the String variable "data".
data = myPort.readStringUntil('.');
data = data.substring(0,data.length()-1);
index1 = data.indexOf(","); // find the character ',' and puts it into the variable "index1"
angle= data.substring(0, index1); // read the data from position "0" to position of the variable index1 or thats the value of the angle the Arduino Board sent into the Serial Port
distance= data.substring(index1+1, data.length()); // read the data from position "index1" to the end of the data pr thats the value of the distance
// converts the String variables into Integer
iAngle = int(angle);
iDistance = int(distance);
void drawRadar() {
pushMatrix();
translate(960,1000); // moves the starting coordinats to new location
noFill();
strokeWeight(2);
stroke(98,245,31);
// draws the arc lines
arc(0,0,1800,1800,PI,TWO_PI);
arc(0,0,1400,1400,PI,TWO_PI);
arc(0,0,1000,1000,PI,TWO_PI);
arc(0,0,600,600,PI,TWO_PI);
// draws the angle lines
line(-960,0,960,0);
line(0,0,-960cos(radians(30)),-960sin(radians(30)));
line(0,0,-960cos(radians(60)),-960sin(radians(60)));
line(0,0,-960cos(radians(90)),-960sin(radians(90)));
line(0,0,-960cos(radians(120)),-960sin(radians(120)));
line(0,0,-960cos(radians(150)),-960sin(radians(150)));
line(-960cos(radians(30)),0,960,0);
popMatrix();
void drawObject() {
pushMatrix();
strokeWeight(9);
stroke(255,10,10); // red color
pixsDistance = iDistance
22.5; // covers the distance from the sensor from cm to pixels
// limiting the range to 40 cms
if(iDistance<40){
// draws the object according to the angle and the distance
line(pixsDistancecos(radians(iAngle)),-pixsDistancesin(radians(iAngle)),950cos(radians(iAngle)),-950sin(radians(iAngle)));
popMatrix();
void drawLine() {
pushMatrix();
strokeWeight(9);
stroke(30,250,60);
line(0,0,950cos(radians(iAngle)),-950sin(radians(iAngle))); // draws the line according to the angle
popMatrix();
void drawText() { // draws the texts on the screen
pushMatrix();
if(iDistance>40) {
noObject = "Out of Range";
else {
noObject = "In Range";
fill(0,0,0);
noStroke();
rect(0, 1010, width, 1080);
fill(98,245,31);
textSize(25);
text("10cm",1180,990);
text("20cm",1380,990);
text("30cm",1580,990);
text("40cm",1780,990);
textSize(40);
text("Object: " + noObject, 240, 1050);
text("Angle: " + iAngle +" °", 1050, 1050);
text("Distance: ", 1380, 1050);
if(iDistance<40) {
text(" " + iDistance +" cm", 1400, 1050);
textSize(25);
fill(98,245,60);
translate(961+960cos(radians(30)),982-960sin(radians(30)));
rotate(-radians(-60));
text("30°",0,0);
resetMatrix();
translate(954+960cos(radians(60)),984-960sin(radians(60)));
rotate(-radians(-30));
text("60°",0,0);
resetMatrix();
translate(945+960cos(radians(90)),990-960sin(radians(90)));
rotate(radians(0));
text("90°",0,0);
resetMatrix();
translate(935+960cos(radians(120)),1003-960sin(radians(120)));
rotate(radians(-30));
text("120°",0,0);
resetMatrix();
translate(940+960cos(radians(150)),1018-960sin(radians(150)));
rotate(radians(-60));
text("150°",0,0);
popMatrix();
pls help me fix this pls.....
Please correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code] and indent the text....
Then tell us what is wrong, what does not work as you want, etc... (you should communicate at 115200 not 9600 for better performance)
This is an Arduino forum. Even if it were a Processing forum, you would need to post the error message. How are we to know what is wrong?
And, you need to tell us what version of Processing you are using. And what OS you have.
