Producing step and direction signals for 8 servo motors
I apologise in advance for being simple! I have a bit of a knowledge of pic and a couple of plcs but never a arduino.
I have an application where I need to control speed and position of 8 motors, they all need to run at exactly the same speed and position relative to each other needs to be maintained from startup.
I have selected the relevant dc servos and servo drives but I need to generate the step and direction signals to control them, direction is easy as I only need to run one direction I can simply tie the direction to Gnd or 5v, step frequency needs a range of 0.5-2 kHz approx.
I've looked a lot at stepper function libraries but they just seem a bit over complicated for what I need to do, I would like to be able to adjust the frequency with a potentiometer and read the frequency being produced on an lcd or similar.
So as far as I can see if I use a simple lcd shield and a potentiometer that should cover the control requirements but as far as the frequency goes is it not possible to connect the step wires two 8 digital outs and then the code (forgive my lack of proper terms) is basically pins 1-8 high, pause an increment read from a registry which the pot is read into and the pins 1-8 low, pause the increment and then loop?
Am I anywhere close or is there an easier way?
thanks in advance
Matt
The simplest solution would be controlling all motors from the same pins. Just hardwire them.
Thanks,
Surely I will run into drawing too much current from one pin? What would be a simple opto isolator or transistor shield to cover this?
Matt
That would depend on the input impedance of the divers. A aduino pin can provide 40mA i believe. If you need exceeds this you have to take one of the measures you mention. or distribute the load between several pins set at the same time.
Just been looking at an adafruit 16 channel servo / pwm i2c shield, is there any chance of making this work?.
Thanks
Matt
yes, but as i see it there is no need
