Hello !!
I'm confused, I show you my code, running on Arduino MEGA and LCD 16x2.
This is my custom charset, a total of 19 characters of 8 bytes each
const byte CCFlash[19][8] PROGMEM = {
{B10000, B10000, B10000, B10000, B10000, B10000, B10000, B10000}, // 1/5 full block,
{B11000, B11000, B11000, B11000, B11000, B11000, B11000, B11000}, // 2/5 full block
{B11100, B11100, B11100, B11100, B11100, B11100, B11100, B11100}, // 3/5 full block
{B11110, B11110, B11110, B11110, B11110, B11110, B11110, B11110}, // 4/5 full block
{B11111, B11111, B11111, B11111, B11111, B11111, B11111, B11111}, // 5/5 full block
{B01100, B10010, B10010, B01100, B00000, B00000, B00000, B00000}, // Grado
{B00100, B01110, B01110, B01110, B11111, B00000, B00100, B00000}, // Bell
{B00010, B00011, B00010, B01110, B11110, B01100, B00000, B00000}, // Note
{B00000, B01010, B11111, B11111, B01110, B00100, B00000, B00000}, // Heart
{B00000, B00000, B01010, B00000, B00000, B10001, B01110, B00000}, // Smile
{B00000, B00000, B01010, B00000, B00000, B00000, B01110, B10001}, // Frownie
{B00100, B01010, B00100, B00100, B01110, B10101, B00100, B01010}, // Armsdown
{B00100, B01010, B00100, B10101, B01110, B00100, B00100, B01010}, // Aarmsup
{B11111, B10101, B11111, B11111, B01110, B01010, B11011, B00000}, // Alien
{B00000, B00001, B00011, B10110, B11100, B01000, B00000, B00000}, // Check
{B00001, B00011, B01111, B01111, B01111, B00011, B00001, B00000}, // Speaker
{B00001, B00011, B00101, B01001, B01001, B01011, B11011, B11000}, // Sound
{B00000, B01110, B10101, B11011, B01110, B01110, B00000, B00000}, // Skull
{B01110, B10001, B10001, B11111, B11011, B11011, B11111, B00000}, // Lock
and this is the procedure to create the characters
void createCustomChars_P()
byte i;
byte CCRam[8];
#define MaxCC 19
for (i = 0 ; i < MaxCC ; i++)
memcpy_P(CCRam, &CCFlash[i][0], 8);
lcd.createChar(i, CCRam);
If I use #define MaxCC 8 it works fine, but obvious only 8 characters.
by example
lcd.setCursor(1, 0);
lcd.write(byte(0)); //print 1/5 full block on lcd
but
If #define MaxCC 19 (all chars, original code) don't create characters in correct position, and when
lcd.write(byte(0));
print another character on LCD.
Any suggestions would be welcome !
Thanks
