Program storage space Maximum ?
a simple sketch to blink LED created using IoT cloud took ,(84%) of program storage space.
Sketch uses 1110945 bytes (84%) of program storage space. Maximum is 1310720 bytes.
adding few lines of codes to read ESP32 bluetooth using
#include "BluetoothSerial.h"
Sketch uses 1792225 bytes (136%) of program storage space. Maximum is 1310720 bytes.
what do you suggest ?
@robots7000,
which partition table are you using for your ESP32 device? if you are not interested in OTA, you should be able to select a different partition table using the web editor that will increase your available program storage space.
