Hello not sure if this is a programing problem or a hardware problem. I program the attiny85 in the past with no problem. But when now i go to program a attiny84 it seems like it works the Blink led sketch works the led blinks but if i disconnect the spi pins the D10 off of the reset pin on the attiny84 and D11, D12 and D13 the led stops working. i have it set to Pin 0 on the Attiny84 which is the second pin on there i follow this image correctly in wiring it up. i listed below and the Sketch of
Blink
Turns on an LED on for one second, then off for one second, repeatedly.
This example code is in the public domain.
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 0;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
// the loop routine runs over and over again forever:
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
It seems to be working for the most part the led blinks and then i take off the pins just to add power and nothing happens can someone please help me out? Thank you.
