I have some code I am using (downloaded it) and it's not working quite right. I was wondering if someone can take a look at it and give me a hand - I am not a programmer.
The code is translating into having 32 pins that are functional - I believe they are all inputs. However, the code is set to have pins 3-45 be outputs and 46-70 to be outputs. The problem is that they are not being recognized as assigned as inputs or outputs beyond pin 32 in JMRI software that I am using. So.... it seems that something may be wrong with this code. Pins 3-31 do act as functional inputs - I tested them and they work by giving me a signal change in the software. Is there something wrong with this code? Or maybe it is something in the JMRI software. Please help - and keep in mind I am not a coder at all - thanks!
// This sketch combines servo turnout control, sensor inputs and other outputs
// Pins 0, 1 and 2 are protected since these are used for communication
// Pin 13 is the Arduino LED pin and should not be used as an input, but can be used as an output for some applications
// Pins 20 and 21 are reserved for PWM servo control
// We will set the Arduino up to behave like a piece of CMRI hardware called a SUSIC with up to 64 slots
// Each slot has either a 24 or 32 bit input/output card
// 64 x 32 bit cards gives up to 2048 input/outputs!
// However, it's best to only set up the SUSIC with the required inputs/outputs to make the process more efficient.
// We will set cards 0 and 1 to be the sensor inputs (up to 64 inputs) and cards 2 - 5 to support 128 outputs
// Include libraries
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#include <CMRI.h>
#include <Auto485.h>
// CMRI Settings
#define CMRI_ADDR 1 //CMRI node address in JMRI
#define DE_PIN 2
// The number of servos connected
#define numServos 1
// Define the PCA9685 board addresses
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(); //setup the board address - defaults to 0x40 if not specified
// Setup serial communication
Auto485 bus(DE_PIN); // Arduino pin 2 -> MAX485 DE and RE pins
// Define CMRI connection with 64 inputs and 128 outputs
CMRI cmri(CMRI_ADDR, 64, 128, bus);
// Create tables to hold data about the servo positions
int Status[numServos]; //Create a table to hold the status of each turnout, signal, etc.
int Throw[numServos]; //Create a table to hold the throw value for each servo
int Close[numServos]; //Create a table to hold the close value for each servo
// SET PINS TO INPUT OR OUTPUT
for (int i = 3; i < 20; i++) {
pinMode(i, INPUT_PULLUP); // define sensor shield pins 3 to 19 as inputs
for (int i = 22; i < 46; i++) {
pinMode(i, INPUT_PULLUP); // define sensor shield pins 22 to 45 as inputs
for (int i = 46; i < 70; i++) {
pinMode(i, OUTPUT); // define sensor shield pins 46 to 69 as outputs
//INITIALISE PCA9685 BOARDS
Serial.begin(19200); //Baud rate of 19200, ensure this matches the baud rate in JMRI, using a faster rate can make processing faster but can also result in incomplete data
bus.begin(19200);
pwm.begin();
pwm.setPWMFreq(50); // This is the maximum PWM frequency
//SET THE THROW AND CLOSE VALUES FOR EACH SERVO BASED ON THE CALIBRATION PROCESS
//Servo connection 0 - point motor
Throw[0] = 1015;
Close[0] = 1800;
cmri.process();
// PROCESS SERVOS
// Assume servos start on bit 0 which corresponds to output address 1001
for (int i = 0; i < numServos; i++) {
Status[i] = (cmri.get_bit(i));
if (Status[i] == 1) {
pwm.writeMicroseconds(i, Throw[i]);
pwm.writeMicroseconds(i, Close[i]);
// PROCESS SENSORS
// Only include lines that are required. This reduces processing time - delete or comment out lines that are not required
// Ensure bit address matches pin, i.e. a sensor attached to pin 17 corresponds to bit 13 (because we've skipped pins 0, 1, 2 and 13) which is address 1014 for this CMRI node
// Do not read 0, 1 or 2
cmri.set_bit(0, !digitalRead(3)); //Bit 0 = address 1001 in JMRI
//cmri.set_bit(1, !digitalRead(4)); //Bit 1 = address 1002 in JMRI
//cmri.set_bit(2, !digitalRead(5)); //Bit 2 = address 1003 in JMRI
//etc.
//Do not read 13
//Do not read 20 or 21
// PROCESS OUTPUTS
// Non servo outputs will start on bit 100, this will be address 1101 in CMRI, bit 101 will be 1102, etc.
digitalWrite(46, cmri.get_bit(100));
// digitalWrite(47, cmri.get_bit(101));
// digitalWrite(48, cmri.get_bit(102));
// etc...
// digitalWrite(67, cmri.get_bit(121));
// digitalWrite(68, cmri.get_bit(122));
// digitalWrite(69, cmri.get_bit(123));
