Programming difficulty about function definition
I was practicing and trying my Analog to Digital Converter (MCP3008) and trying this simple test. And here is my code :
#include <Adafruit_MCP3008.h>
Adafruit_MCP3008 adc;
  float voltage(int raw){
  return raw / 1023 * 4.9;
  while (!Serial);
  Serial.println("MCP3008 simple test.");
  adc.begin();
  int raw = adc.readADC(0);
  Serial.print(raw);
  Serial.print("\t");
  Serial.println(voltage(raw));
and when I opened my serial monitor it only showing the changes of "raw", but my "voltage" function seems not get included, here is what I got, as you can see it only shows the result for raw (on left), but not showing the voltage (on right)
Screenshot (62)
I'm trying to make sure I got the "voltage" function affected also inside the void loop. can anybody explain me the rule of program in this case ?
Try this
  return raw / (1023 * 4.9);
return raw / 1024.0 * 4.9;
Do the maths.
119/1023 = 0.116 so as an integer the result is 0.
so 0 * 4.9 = 0
You need to look at using float rather than int variables.
Tom.. :smiley: :+1: :coffee: :australia:
PS. Do the multiplication before the division.
So with an int as parameter
  // it is important to have the "1.0" DOT-ZERO
  // to make the compiler handle it explicit as float
  float myFLoat = raw * 1.0;
  myFLoat = myFLoat / 1023 * 4.9;
  return myFLoat;
or simply
float voltage(float raw){
OMG thanks for the clear info, so the problem was the mathematical order damn....
I tried this and it solved
  return (raw * 4.9) / 1023 ;
thank you for noticing the problem guys
Or, correctly, divide by 1024.
It's a small thing, but small things can be important (unlike Andrew Tate's you-know-what)
yup yup silly me, now my problem fixed by doing this :
thank you
yup thank you for noticing first, I did this instead :
and it fixed my program issue, turn out it was not the function definition, it was mathematical order, silly me :sweat_smile:
