Programming gets error when ping sensor code combainec.
Here is my code.
//Ping Sensor
long duration, inches, cm;
const int trigPin = 4;
const int echoPin = 5;
int pinI1=8;//define I1 interface
int pinI2=11;//define I2 interface
int speedpinA=9;//enable motor A
int spead =50;
pinMode(pinI1,OUTPUT);
pinMode(pinI2,OUTPUT);
pinMode(speedpinA,OUTPUT);
void forward()
analogWrite(speedpinA,spead);
digitalWrite(pinI2,LOW);
digitalWrite(pinI1,HIGH);
void backward()//
digitalWrite(pinI2,HIGH);
digitalWrite(pinI1,LOW);
void stop()
digitalWrite(speedpinA,LOW);
// establish variables for duration of the ping,
// and the distance result in inches and centimeters:
// The sensor is triggered by a HIGH pulse of 10 or more microseconds.
// Give a short LOW pulse beforehand to ensure a clean HIGH pulse:
pinMode(trigPin, OUTPUT);
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Read the signal from the sensor: a HIGH pulse whose
// duration is the time (in microseconds) from the sending
// of the ping to the reception of its echo off of an object.
pinMode(echoPin, INPUT);
duration = pulseIn(echoPin, HIGH);
// convert the time into a distance
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
delay(100);
long microsecondsToInches(long microseconds)
// According to Parallax's datasheet for the PING))), there are
// 73.746 microseconds per inch (i.e. sound travels at 1130 feet per
// second). This gives the distance travelled by the ping, outbound
// and return, so we divide by 2 to get the distance of the obstacle.
// See: http://www.parallax.com/dl/docs/prod/acc/28015-PING-v1.3.pdf
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds)
// The speed of sound is 340 m/s or 29 microseconds per centimeter.
// The ping travels out and back, so to find the distance of the
// object we take half of the distance travelled.
return microseconds / 29 / 2;
if(inches==10)
stop();
When compiles it shows that "expected qualified-id before if."
Why it shows like it.
Iam in a run for science working model competition. I'm making autonomous arduino vehcle. Friends can youhelp me to resolve the programming code.? It will be very useful if you help me.....
 if(inches==10)
stop();
Is not in a function.
Please use code tags when posting code.
