I am trying to write a program where if an input goes over a certain voltage then an output LED will blink. I wish to keep this LED blinking for 10s and if the input is still high after the 10 seconds then I would like turn off the blinking LED and make another 2 outputs high.
Any idea how I would go about it?
Yes. The question is what parts of what you want to do are you having issues with? Detecting when an input transitions from below the threshold to above the threshold is simple.
Detecting when the transition from above the threshold to below occurs is easy.
Determining if now minus then exceeds a value is trivial.
Determining whether it is time to toggle the state of the LED is trivial. Doing so is even more trivial.
First get a reading of the pin at the required voltage, make a note of its value. "IF" incoming voltage is equal to the measured value, get the current millis() and store it in a variable. Now use another IF statement to check the difference of the new current "millis() - the stored millis " and see if it is greater than 10000UL (10 seconds), and still high. If it is greater than 10 seconds and still high, LED OFF and your 2 pins ON.
So you need to code in 3 IF statements. Check voltage, set timer, check timer and voltage. The rest after that is up to you.
Basically this code is for a burgular alarm. What I want it to do is monitor the input coming from a PIR and another input coming from a mic. All the electronics is sorted, I am just having a bit of trouble with the code. The aim is to get the code so that when eitherof inputs are high, an LED will flash. Then after a delay of 10s, if the input is still high, the Arduino will go low on the output to the blinking LED and go high on another 2 outputs. These outputs are going to another LED and a buzzer. My code does not seem to be working at all and I am getting high outputs even if none of the inputs are high. Any ideas peeps????
int MIC_IN_A1 = 1; //Declares an integer of Mic input
int PIR_IN_A2 = 2; //Declares an integer of PIR input
int RESET_A3 = 3; //Declares an integer of Reset input
int LED_PIR = 11; //Declares an integer of LED for PIR
int BUZZER_PIR = 12; // Declares and integer of buzzer for PIR
int LED_MIC = 9; //Declares an integer of LED for MIC
int BUZZER_MIC = 10; // Declares and integer of buzzer for MIC
int LED_ WARN_MIC = 2; //Declares an integer of LED MIC warning
int LED_WARN_PIR = 3; // Declares and integer of LED PIR warning
long aRead = 0; //Assumes voltage range from input
#define N_READINGS 10
Serial.begin(9600); //Serial console for debugging
pinMode(LED_PIR, OUTPUT); //Sets led PIR as an output
pinMode(BUZZER_PIR, OUTPUT); //Sets buzzer PIR as an output
pinMode(LED_MIC, OUTPUT); //Sets led MIC as an output
pinMode(BUZZER_MIC, OUTPUT); //Sets buzzer MIC as an output
pinMode(LED_ WARN_MIC, OUTPUT); //Sets Mic LED Warning as an output
pinMode(LED_WARN_PIR, OUTPUT); //Sets PIR LED Warning as an output
StartTime = millis (); // should this be declared elsewhere?
CurrentTime = millis (); // should this be declared elsewhere?
int readVoltage (int pin)
long aRead = N_READINGS / 2; //pre-round the result
for(int i=0; i < 10; i++) //Takes 10 readings
aRead += analogRead(pin); // The analogue inputs are being read
aRead = aRead / N_READINGS; //Takes the average of 10 readings
float voltage = (aRead * 5.0)/1024.0; //Converts to digital
Serial.print(" Voltage on pin ");
Serial.print(pin);
Serial.print(" is ");
Serial.println(voltage);
return voltage*1000; //converts to millivolts
bool ResetActive = false; //sets a flag for reset which will be used later
bool MicActivate= false; // sets a flag for the MIC being activated
bool BlinkMicWarnLED = false; //sets a flag of Mic being triggered
bool PirActivate = false; // sets a flag of the PIR being active
bool BlinkPirWarnLED = false; // Sets a flag of the PIR being triggered
float voltage = readVoltage(MIC_IN_A1); //reads the voltage on the MIC in pin
if(voltage >= 4000 )
{ //If voltage more than 4V
BlinkMicWarnLED = true; //makes my flag true if the criteria is met
if(CurrentTime-StartTime > 10000); // Counts upto 10 seconds
if(voltage >= 4000) //reads voltage again after delay
BlinkMicWarnLED = false; //makes my flag falseif the criteria is met
MicActivate = true; //makes the Mic alarms flag true
voltage = readVoltage(PIR_IN_A2); //reads the floating voltage on the PIR in pin
if( voltage >= 4000 ) //If voltage more than 4V
BlinkPirWarnLED = true; //makes my flag true if the criteria is met
if( CurrentTime-StartTime > 10000); // Counts upto 10 seconds
if (voltage >= 4000 ) //reads voltage again after delay
BlinkPirWarnLED = false; //makes my flag falseif the criteria is met
PirActivate = true; //makes the Mic alarms flag true
voltage = readVoltage(RESET_A3); //reads the floating voltage on the Reset in pin
if(voltage >= 4000) //If voltage more than 4V
ResetActive = true; //makes my flag true if the criteria is met
if (BlinkMicWarnLED == true) //If this is true depending on the above criteria being met
Serial.println("MIC Warning...");
digitalWrite(LED_ WARN_MIC, OUTPUT, HIGH); //Gives 5V output to LED
delay(100); // Keeps LED on for 100mS
digitalWrite(LED_WARN_MIC, OUTPUT, LOW); //Turns off LED warning output
else if(MicActivate == true) //Mic has been activated for longer than delay
Serial.println("Burglar picked up by MIC...");
digitalWrite(LED_MIC, HIGH); //Gives an output to MIC LED
digitalWrite(BUZZER_MIC, HIGH); //Gives an output to MIC Buzzer
else if(BlinkPirWarnLED == true) //If this is true depending on the above criteria being met
Serial.println("PIR Warning...");
digitalWrite(LED_ WARN_PIR, HIGH); //Gives 5V output to LED
digitalWrite(LED_ WARN_PIR, LOW); //Turns off LED warning output
else if(PirActivate == true) //PIR has been activated for longer than delay
Serial.println("Burglar picked up by PIR...");
digitalWrite(LED_PIR, HIGH); //Gives an output to PIR LED
digitalWrite(BUZZER_PIR, HIGH); //Gives an output to PIR Buzzer
else if(ResetActive == true) //If the reset switch is activated
Serial.println("Reset Is Activated...");
digitalWrite(BUZZER_MIC, LOW); //No output Mic buzzer
digitalWrite(LED_MIC, LOW); //No output to Mic LED
digitalWrite(BUZZER_PIR, LOW); //No output PIR buzzer
digitalWrite(LED_PIR, LOW); //No output to PIR LED
else // If nothing at all is activated
Serial.println("All Is Clear...");
digitalWrite(LED_ WARN_PIR, LOW); // No output to PIR warning LED
digitalWrite(LED_ WARN_MIC, LOW); // No output to MIC warning LED
delay(100); //100mS delay between measurements
No matter your desires, you can’t have spaces in variable names.
You can’t have untyped variables, either.
Serial.print(pin);
Why is there a return in the for loop?
There is no reason to convert the reading to millivolts. Just use the raw (integer) reading.
What is this supposed to do? Back to the reference docs for you.
Using Tools + Auto Format
before posting
code is appreciated.
Too bad you
couldn’t be bothered.
