Project 03 serial monitor problem
Hi, why can't I see the Serial monitor? When I click on the icon I only see it a the bottom of the page and I can't see the temperature values, nor anything else...
Thanks a lot in advance!
Why can't I see all your code? Hint, follow the posting guidelines.
Also, it would seem your problem is with the V2.x IDE, so that's likely where this should be asked.
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
Please post your full sketch, using code tags when you do
Posting your code using code tags prevents parts of it being interpreted as HTML coding and makes it easier to copy for examination
In my experience the easiest way to tidy up the code and add the code tags is as follows
Start by tidying up your code by using Tools/Auto Format in the IDE to make it easier to read. Then use Edit/Copy for Forum and paste what was copied in a new reply. Code tags will have been added to the code to make it easy to read in the forum thus making it easier to provide help.
It is also helpful to post error messages in code tags as it makes it easier to scroll through them and copy them for examination
What baud rate have you got in Serial.begin() and what baud rate is the Serial monitor set to ?
Click on the divider line and drag it up the screen...
